Pitbull Front Stand - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 10-13-2003, 12:10 PM Thread Starter
Kidder's Avatar
Pitbull Front Stand
I have a set of Pit Bull stands that I used with my SV. I didn't get the centerstand for the Strom since I already had the Pitbulls.
FYI, the front stand will not lift the front of the bike as of now. Apparently, the pin that they had listed for the Strom is too short.
I'm going to take some measurements tonight and send them into
Pitbull since they've requested that from me. And, they plan on making either a different pin or an adapter for the pin that's slated for use with the Strom.
Does anyone live in or around Huntsville, AL that could take their Strom in as a test case? This would be more ideal so they could have it there to use.
Kidder is offline
post #2 of 3 Old 10-15-2003, 11:47 AM
I use my Pitbull stands on my V-Strom with just one change. I have the "new" front stand, and it won't lift the front high enough, so I have to put a board under each wheel of the stand to get the tire to clear the ground. The pin is the same on I use on my GSXR, and a few others. I can't figure out what problem you're having.
post #3 of 3 Old 10-16-2003, 09:48 PM Thread Starter
Kidder's Avatar
That's the problem
That's the problem, the stand doesn't get high enough. They're going to have to fabricate a new pin, more than likely.
Currently Bikeless
Kidder is offline
Front wheel stand Jim12X DL650 and DL650A - 2004 to 2011 7 06-01-2018 11:54 PM
New SV Racing Parts, Adjustable Height Stem Lift Front Stand for All Vstrom Models. SV Racing Parts SV Racing Parts 12 10-25-2014 11:01 AM
Center Stand and Front Wheel Lift eweingarden General V-Strom Discussion 9 09-22-2014 07:51 PM
Front triple-tree stand with ABS Wee? MisterB DL650 and DL650A - 2004 to 2011 0 03-25-2012 08:13 PM
vortex front stand? dtalk DL650 and DL650A - 2004 to 2011 2 06-04-2009 01:43 PM
