Setting Clock - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 04-03-2005, 12:49 AM Thread Starter
Setting Clock
I went out to set my clock ahead and according to the manual for the DL650 you push both buttons on the dash simultaneously to get the display to flash. I found on my bike that I have to push the Select button first then the adjust button next and then proceed to hold them both in until the display flashes and the ignition has to be on also. I hope this may help those of you who haven't set your clock yet for Daylight Savings Time.
Dan
trailbuster30 is offline
post #2 of 4 Old 04-06-2005, 06:04 PM
Delta88's Avatar
That's a relief. I just had a similar problem with mine. I bought it wrecked so I had to wonder if, maybe something had happened internally. Hopefully, I won't have to perform that operation for 6 more months. :P
Tim
CSBA #542
IBA #16689
NESBA #23887
Delta88 is offline
post #3 of 4 Old 04-06-2005, 09:54 PM
It's another good excuse to get a second bike.
You have one bike set for daylight savings time and the other on the other time. Just check the calendar and make sure you use the proper bike.
:lol:
2004 V-Strom 650
2002 GS500
2004 KLR250
2014 DRZ400
mike183 is offline
post #4 of 4 Old 04-07-2005, 09:28 PM
TomStromie's Avatar
As someone on the Yahoo DL650 group pointed out, just wait a bit and the clock will self-adjust.
TomStromie is offline
