Help ! Rounded off allen bolt - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 03-18-2005, 01:50 PM
Munchy
Hi !
I was a bit sloppy when trying to install my motech (which Suzuki GB use as the OEM version, if anyone's interested) crashbars, and I've rounded off one of the hex bolts (which appear to be made out of some metal slightly sturdier than cheese...)
How do I get the bugger out ? I've cut a slot across the top with a dremel, and got a monster screwdriver in there, but no amount of turning (or swearing!) will budge it, and I'm not a little fella...
Should I drill it ? Any better ideas ?
James.
post #2 of 5 Old 03-18-2005, 02:30 PM
They have blue loctite on the threads. Since you have a nice cut made from the dremel tool, you might try using an impact driver. I bet it'd break loose.
looks like this...
http://www.sears.com/sr/javasr/produ...id=00947641000
RubberDown is offline
post #3 of 5 Old 03-18-2005, 05:41 PM
MNwilly
I always have a set of cheap torx bits that I use just for this problem. Find the one that will just start and pound it in. Oh, and the impact drivers work great on any screw head fastener.
post #4 of 5 Old 03-18-2005, 05:46 PM
Munchy
Great - thanks guys. I'll pick one up tommorow and report back on the results....
I'm going to enjoy walloping it anyway - its been really bugging me !
post #5 of 5 Old 03-19-2005, 09:52 AM
Munchy
Success...Had to beat the crap out of it, but it finally moved...
http://banjostring.co.uk/gallery/DL650/CIMG0535
Thanks for the tips....
