Headlights gone - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 11-14-2013, 12:26 PM Thread Starter
$tromTrooper
MTNAdventureRider's Avatar
Headlights gone
Guys I need help ASAP. Supposed to leave on a trip in 4 hours and I have no headlights.
I have read all the threads on the forum about this problem.
Fuses good
Checked connections behind the cowling and behind radiator
Check high low switch
Checked starter button
Right now, the fuse block for high and low beam fuses is getting no juice
Funning thing is...last night when I disconnected the connector behind the radiator, the lights came on. Then started to put the airbox back on and lost them again and haven't gotten them back.
Any and all help is greatly appreciated.
Thanks.
Big John
2007 DL650 - Gone but not forgotten
MTNAdventureRider is offline
post #2 of 7 Old 11-14-2013, 12:35 PM Thread Starter
$tromTrooper
By the way, everything else is working......blinkers, etc.....
Big John
post #3 of 7 Old 11-14-2013, 12:38 PM
Any mods or additions to the wiring system by chance?
post #4 of 7 Old 11-14-2013, 12:45 PM Thread Starter
$tromTrooper
Only a DC plug for charging the phone.....but it comes straight from the battery.
My concern is that there is no charge to the high and low beam fuses.
What should I check before that?
Big John
post #5 of 7 Old 11-14-2013, 01:20 PM
By far, the most common problem is the starter button switch. If the contacts there are not made, the power won't make it to the fuses. Check the Y/W wire coming off the right handlebar switch. If it is hot, the next most likely places are the connections behind the radiator shroud. Two will have Y/W wires. They need to be hot on both sides of each connector. Problems like this are why I keep telling people to install headlight relays before connections and contacts go bad.
post #6 of 7 Old 11-14-2013, 01:22 PM
A poor connection in this area?
2007 DL 650 with assorted upgrades
Solo is offline
post #7 of 7 Old 11-14-2013, 01:40 PM
Vinegarjoe
lites out
ditto what GW said, probably little white switch (rectangular) within right handlebar accelerator/ignition assembly. Rolled off ketchikan ferry in the dark when mine failed (07 wee).
Vinegarjoe is offline
