TPS Adjustment on the DL 650 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 26 Old 02-14-2005, 11:47 PM Thread Starter
Hello,
There seems to be lots of documentation about the TPS adjustment on the DL 1000~~~ Floating around the internet...
However,
Online documentation for the 650 seems to be absent.
First thing I see~~ I think.. The TPS is in a different place. ? .
I have the Service Manual and Plan to use the method where you check the voltage with a Multimeter on the TPS ...
Not look for the c-14 code ( or whatever that is)
I will be doing a TBS/ TPS...
Anyone got any advice on the TPS Adj for the 650.... Any good hints or things to watch for......
Thanks
Chris
04 DL-650
Have a good time, ALL the time !
Chris is offline
post #2 of 26 Old 03-23-2005, 10:18 PM Thread Starter
Hey,
Today I adjusted my TPS. I am VERY Happy with the way it turned out.
Here is some history. 04 DL650, 6300 miles.
When I first got it, it ran perfect... throttle & engine very smooth.
Over time things got Buzzy.. I thought : OK I gotta sync the TB's ..
Yes they were out by about 12". I synced them.
Then things felt better but now I was Buzzy in a different place, on acceleration at 4, 5 and 6 thousand RPM. Buzzy in the Seat of the pants and Bars, Bike felt like it was working against itself, not that "electric" feeling.
Last week I checked the sync again, it was out a little, I adjusted.
Buzz was not going away, seems like over time it got worse.
I know everywhere you read about the TBS they also say adjust the TPS.
Well I was reluctant, because I didnt really understand the process...
I read a lot of documentation on the DL-1000 but I was never 100% sure the process was the same on the DL-650.
Also, the other Strom forum and FAQ shows a process that utilizes a multimeter and checking the voltage at the TPS.
This Multimeter process is good ( I think ) but I didnt want to remove the Airbox all the way.. So I used the other method using the bikes Dealer Mode..
Here is the Tutorial I followed.. it is very good
http://forums.sv650.org/viewtopic.ph...&highlight=tps
As you can read they predict your TPS will jump to the next level at about 3000 rpm... thats where mine jumped up..
I was able to adjust mine to jump up at about 1700 RPM.
The result: Much Much Smoother acceleration. Buzz is gone.
Be warned, when you loosen and move the TPS it is EXTREMLY SENSITIVE.
Meaning, if you just breath on the TPS it is Way out of adjustment.....
So you have to take your time and be real patient... But dont give up
You can get it there.
I took it out for a test spin... Runs very very good, much smoother.
feels like it did when I first got it.
Best Regards !
Chris
04 DL-650
Chris is offline
post #3 of 26 Old 03-24-2005, 07:49 AM
Bobb_Todd
I had mine checked at 12k kilometers. Was still spot on.
I'm having it rechecked now at 33k but it's still smooth so I don't expect it to be out much if any.
Valves were also within spec at both 12k and 33 k
post #4 of 26 Old 04-07-2005, 11:24 AM
cyclerama2000's Avatar
WOW!!! That guy wrote an excellent article about the SV650.
For those who have done this adjustment, are the numbers and procedures EXACTLY the same for the DL650?
I've found out through the years that these forums make do-it-yourself items easy and inexpensive and much more reliable than having a dealer mess with a bike.
Originally Posted by Chris
Hey,
Best Regards !
Chris
cyclerama2000 is offline
post #5 of 26 Old 04-07-2005, 02:04 PM
GLAD I SAW THIS THREAD
WAY TO GO CHRIS [3/23/05 ENTRY]
This is exactly the tutorial I needed. things are making much more sense now!
Zapp
If evolution is valid, why do I still bite my tongue occasionally?
zapp is offline
post #6 of 26 Old 04-07-2005, 03:09 PM Thread Starter
Cycelrama : Yes DL-650 and SV-650 Same Engine.. The Specs are identical.. I used the process just as it is written... worked perfect
3 weeks later .. the bike its still running PerfectO ..
HEY ZAPP !! I know.. it clarifies a lot... it's not as hard as you think (thats what she said)
Best Regards !
Chris
04 DL-650
Chris is offline
post #7 of 26 Old 08-30-2005, 03:31 PM
Finally got around to performing this TPS adjustment on my '04 DL650 as well as my GF's '04 SV650N. On the SV650 it made a big difference in low-speed throttle control--this bike's herky-jerky character in low speed turns and parking lot maneuvers was rather irritating. The GF thinks it also revs more freely through the midrange also, but I'm skeptical. Then again I don't ride her bike that much and when I do I'm usually cracking it open as hard as conditions permit and grinning widely. On the DL650 I do notice smoother low-speed throttle response but not as big a change as on the SV. This makes sense to me as the DL650 throttle wasn't quite as snatchy as the SV to begin with. I think just as the greater pork of the DL slows it down relative to the SV, the off-throttle deceleration wasn't quite as abrupt likely due to it's greater momentum. Overall, it's an adjustment worth making because it's easy and there's no downside. Since different bikes may come from the factory with slightly different TPS settings, the improvement may be larger on some especially herky-jerky bikes.
moto_potato is offline
post #8 of 26 Old 08-30-2005, 09:39 PM
the cams are significantly different to put the power down low in the rpm range on the DL. I don't know about the gearing [what's the toothies on the SV?]
z
zapp is offline
post #9 of 26 Old 03-23-2014, 11:33 AM
Running rough
Ok so I have a question about the TPS. First of all I have a 09 dl650 and itís running rough at low speedsÖjerky, I think you guys know want I mean. From what Iíve read I think itís the TPS. So I put my bike in dealer mode and I get ĖC 00. Does that mean may TPS is ok?
Thodak Dragonsbane
Thodak is offline
post #10 of 26 Old 03-23-2014, 01:22 PM
It means the TPS is reasonably adjusted. The best adjustment is if the dash first raises when held at about 2500rpm. Adjustment is different from function. A well adjusted but worn TPS can cause stalling. Rough running at low speeds can have a number of causes. A bad TPS normally show up as an inability to idle after a long cruise.
What speeds and rpms gear selection are involved when running rough? Word your response like 3000rpm in sixth at 40mph, or 2000rpm in first at 10mph or the like.
