Is my battery dying? Weird 'won't start' event... - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 07-29-2013, 05:48 PM Thread Starter
shevett's Avatar
Hey folks! I was out riding on Sunday doing something that involves a lot of stops and starts (Ingress if anyone knows it, if you don't, dont' worry about it). At one stop, I was idling for perhaps 3 minutes, and went to move off... now, my bike stalls easily - I chalk this to "I rode a big heavy 4 cylinder bike for ages, these tighter 2 cylinder engines are not as forgiving". The stalls usually are "one cylinder fires, then the 'fwee' sound of a miss, and it stops".
A quick buttonpush and I'm usually on my way again (I've done this rolling into intersections even).
This time,however, there was a very weak turnover, and my instrument panel reset (gauges rolled right and left, clock reset to 1:00).
After checking over everything and trying a whole combination of things, I had to admit "This is behaving like the battery is dead.". I rolled the bike up a little incline, down again and popped it in third gear, and it started right up.
After I rode home (being careful to avoid a stall), I shut it down outside the carpark, and started it again. Ticked over perfectly! No problem. I've started it 3 times since then, and every time, no battery or "slow turnover" problem, it's a perfect "hit the power, get the fuel pump whine, push start, it starts right up" sequence.
Talking with a friend who has experience with the Stroms, he points out that they start acting twitchy when the battery is on it's way out. Before I drop bucks on a replacement battery, I call to the wisdom of the Troopers. Is this an indication of a dying battery?
I have no electronics on the bike that are not self-powered, so there was no random drain going on.
Thanks!
[FONT="Lucida Console"]
Dave Shevett - KB1FWR - Berlin, MA
'04 DL650 "The Wee"
'78 GS850 "The Beast!"[/FONT]
shevett is offline
post #2 of 8 Old 07-29-2013, 06:05 PM
Those are low power signs. A marginal battery or cable connection are the things to check.
post #3 of 8 Old 07-29-2013, 06:10 PM Thread Starter
shevett's Avatar
I have moved my battery connection once, but that was weeks and weeks ago, and it's secure and strong (I checked that). Got a suggestion on the best way to get a battery tested? Is this just Joe Bob's garage and use a battery tester? Ohh, wait, there's a Batteries Plus down the street, I can probably have them do it. Hmmm!
'04 DL650 "The Wee"
shevett is offline
post #4 of 8 Old 07-29-2013, 06:40 PM
Check your voltage over 13.4 at 3000 rpm
richw is offline
post #5 of 8 Old 07-29-2013, 06:59 PM
CanadianFZ6's Avatar
How old is the battery?
2015 DL650AL5 in Blue
CanadianFZ6 is offline
post #6 of 8 Old 07-30-2013, 12:00 AM
Rolex's Avatar
Try this post
https://www.stromtrooper.com/general-...r-battery.html
2014 V2, Snoopy
2009 Wee, Pumbaa the pig
WR450F, The Blue Postie Bike
Club Lead not Club Med.
He with the most toys wins.
Out of my depth in a puddle.
Rolex is offline
post #7 of 8 Old 08-06-2013, 11:07 AM Thread Starter
shevett's Avatar
Update...
So on Sunday I hauled the battery out of the Wee and took it to the local Batteries+. These guys have been super-helpful in the past. They tested it on two different battery testers, and both showed an output of 11v (should be 13.5, looks like a dead cell).
Low voltage is a sure indicator of a blown battery, so I replaced it. Things have been running perfectly since.
Thanks for everyone's feedback!
'04 DL650 "The Wee"
shevett is offline
post #8 of 8 Old 08-23-2013, 01:49 AM
Talking
Had the same issue on an old kawasaki...the battery was a cheap quick fix, thank god.
V-Nick is offline
Tags
battery , dl650 , stall
