Oil Filter Choices - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 28 Old 01-05-2005, 07:37 AM Thread Starter
Oil Filter Choices
all :?:
I took a tip from some article somewhere about substituting a Purolator filter for the OEM one [oil that is], but found it would not work due to thread differences.
can someone give me the shortlist of excellent alternatives to the Suzuki filter? [who makes the Suzuki filter anyways?]
Zapp
If evolution is valid, why do I still bite my tongue occasionally?
zapp is offline
post #2 of 28 Old 01-05-2005, 07:56 PM
From what I have read, if you do find another make of filter the casing is not strong enough for the two turns needed.
scooter is offline
post #3 of 28 Old 01-05-2005, 08:11 PM
NAPA Gold Filter 1359
This is a decent filter that I use on my Strom. It costs a few dollars less than the Suzuki part and will not mess up your warranty. See Moss Magnuson Act for details... You can install this filter with two turns, no worries there.
I don't buy these filters to cheat my dealer out of a sale, it's just that the NAPA parts store is right near my house and the Suzuki shop is WAY on the other side of the valley. I'd buy them from Suzuki if I remembered to, but I usually don't.
I used NAPA filters on my Concours for years and years with excellent results. In the case of that bike, the dealer price with the needed o-ring kit was almost double the NAPA price which included the o-rings. Those filters came from NAPA on purpose.
Ride well (filtered).
Jeff
'06 DL-1000
'06 KLX 250S (more fun than people should be allowed to have)
'72 SL-350 K2 (bump start only)
'72 CL-350 (on injured reserve list at this time)
I guess it's better to bend a valve in Missoula than to lose your mind in Bozeman.
-Barb Egan
MWValley is offline
post #4 of 28 Old 01-09-2005, 10:41 PM
Puralator is OK I use em in my car.
Stay Away from FRAM... they Suck
On the DL I use a K&N, I like the NUT that comes welded on it.. makes tightening it (the 2 full turns) real easy. and it's drilled for safety wire.... If that falls into your needs.
K&N ....Excellent Quality .. go for it
Chris
04 DL-650
Have a good time, ALL the time !
Chris is offline
post #5 of 28 Old 01-10-2005, 09:31 AM Thread Starter
Chris: WHICH purolator
chris I tried purolator, but obviously the cross-ref we looked at was wrong because the threads were way different. size and etc was right... threads wrong. help
Zapp
zapp is offline
post #6 of 28 Old 01-11-2005, 10:19 PM
Try www.pureoil.com/ click applications all bikes there
Embrace each day with enthusiastic indifference
YLO-JKT is offline
post #7 of 28 Old 01-13-2005, 01:20 AM
gunnar#1
hiflo good price, motorcycle specific, and an oem supplier, according to the web site, i agree with the fram comment they are junk. i only paid $7 for my hiflo #hf138.
post #8 of 28 Old 01-17-2005, 01:50 PM
I've noticed that all oil filters for the DL have what looks like some kind of leakdown or pressure relief valve built in to the filter. you can actually take a screwdriver and push on it and it will move up and down about 2mm. In some of the after market filters this valve is plastic- Fram,Napa etc. In the suzuki filter it is metal. Dan
trailbuster30 is offline
post #9 of 28 Old 01-17-2005, 05:51 PM
I'm new here, and should pick up my 05 650 V-strom Wed.
Two questions.
How much does the Suzuki filter cost, and how many follow the recommendation of changing at 600 and them waiting until 11,000 miles for next filter change?
I've almost always changed oil and filter together.
DaveJ is offline
post #10 of 28 Old 01-17-2005, 06:00 PM Thread Starter
I broke mine in hard [following two articles I read on the topic], changed first at 100 miles, oil and filter because the metal will clog the filter. Next change at 800 miles, inspect oil before trashing filter: if there is still metal then dump the filter. if just sooty, keep filter.
after that [breakin] do both at every 5000 miles.
suzu filter 14 bucks! ouch, but no alternative
z
zapp is offline
