Purpose of CCT oil jets? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 05-17-2013, 02:24 AM Thread Starter
I did a forum search but found nothing. What purpose do the cam chain timing oil jets serve? I've Googled it but still can't find the info. Holding the adjuster in my hand and inspecting it, it appears that pressurized oil is pushed into the adjusting plunger toward the guide.
'92 Honda Z50R
'94 Kawasaki KLX250 modded to 340cc's
'00 Yamaha YZ426F
'94 Yamaha 125 scooter
'05 Vespa E4 scooter
'68 Vespa VBB scooter (restored)
'06 Wee
'03 Honda S2000 roadster
Boit4852 is offline
post #2 of 9 Old 05-17-2013, 10:28 AM
Downs's Avatar
They probably pressurize the cam chain tensioner. Most tensioners are hydraulic and pressurized by engine oil. They have a ratcheting mechanism that retains the chain adjustment after you shut down the engine and the oil pressure bleeds off.
Not all adjusters have the ratchet though. My old F800 had no ratchet mechanism so the chain was rattly at first start up during the day.
Downs is offline
post #3 of 9 Old 05-17-2013, 10:43 AM
Strom cam chain tensioners are strictly mechanical. A light spring applies the pressure rather than oil. I would guess the #8 oil jet next to it is to keep the ratcheting mechanism clean and lubricated.
post #4 of 9 Old 05-18-2013, 01:27 AM Thread Starter
Thanks for the replies. I'm having a hard time getting my brain wrapped around this. As I held the tensioner in my hand and inspected it, I could see where oil is fed thru the tensioner body towards the rod/plunger or whatever it is called. Once I re-installed the cams and then the tensioner, the spring pushed the plunger against the guide which tightened the chain fairly snug. I went on to re-check the valve lash and the engine had yet to be started so there was no hydraulic tensioning going on....just tension provided by the spring. Sorry to be stuck on this detail, but I have that drive of needing to know.
'92 Honda Z50R
'00 Yamaha YZ426F
'06 Wee
Boit4852 is offline
post #5 of 9 Old 05-18-2013, 06:42 AM
CanadianFZ6's Avatar
While your at it then, maybe you can figure out how Cadbury gets the cream into their Easter cream Eggs? I mean, since you have that "drive of needing to know" kinda' guy.....:biggrinjester:
2015 DL650AL5 in Blue
CanadianFZ6 is offline
post #6 of 9 Old 05-18-2013, 10:05 AM
Scott E. Bonds's Avatar
GW has the correct info. The spring does not push straight against the plunger. It rotates a screw mechanism that has a one way ratchet. As the guide wears or slack is taken up the plunger extends and the ratchet holds it there. It is easy to install one wrong. The plunger should be retracted, the mechanism installed and the plunger then released. At least on the Hondas I have replaced. Suzuki's tensioner looks the same.
2007 Blue SuperVee 1000
2000 Red Honda XR 400r
Scott E. Bonds is offline
post #7 of 9 Old 05-20-2013, 05:01 AM Thread Starter
I'll check with the irs(note; lack of capitalization). They keep these secrets in a vault.
'92 Honda Z50R
'00 Yamaha YZ426F
'06 Wee
Boit4852 is offline
post #8 of 9 Old 05-20-2013, 05:37 AM Thread Starter
Thanks for the description. How does the spring pressure cause a screw to rotate? I'm now more lost than ever. I wish I could see a cut-a-way of this mechanism. Insomnia will strike again tonight.
'92 Honda Z50R
'00 Yamaha YZ426F
'06 Wee
Boit4852 is offline
post #9 of 9 Old 05-20-2013, 11:01 AM
It's not a screw. It's a pawl. The coil spring inside pushes the dark colored toothed rod outward against the cam chain guide. The ratchet allows the rod to extend but not retract. When the cam chain stretches enough, the ratchet clicks into the next notch. Pressing the ratchet at the red arrow releases it from the notches and allows the rod to be pushed back into the body. That's how the cam chain can be loosened for a valve clearance adjustment on a 650 by only removing the center screw and spring. Take them out, push the ratchet at the arrow and lift the cam chain.
