Worn Bar Ends - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 11-09-2004, 07:37 AM
GB #121
Worn Bar Ends
Black paint has scrubbed off the bar ends, looks like hell. Was going to replace them but dealer says that the stock design is minimising vibration in the grips. Anyone used an aftermarket replacement or the smaller buttons? Or just paint the stock ones?
post #2 of 8 Old 11-09-2004, 02:32 PM
Send a message via AIM to Mishadbull Send a message via MSN to Mishadbull
Hey I just found these at Twisted throttle and thought they might be something you are looking for. The stock ends minimise vibrations by adding mass to an oscilating system. these add more mass and should make the bars even smoother than they are already. Though I am sure that you could repaint or powdercoat your stckers for alot less.
Sw motec Bar ends
mike
Scars are a way to prove to us that the past was real.
[url]http://mishadbull.tripod.com/trip[/url]
Mishadbull is offline
post #3 of 8 Old 03-15-2005, 05:08 AM
GB #121
Hi
Anybody found anything new about bar ends. Now that I'm riding again, the weathered/scrubbed bar ends look a bit tacky. The Twisted Throttle link isn't there anymore.
Suggestions? Anybody got similar problems with the DL1000?
post #4 of 8 Old 03-15-2005, 07:36 AM
jirvine
Get a little black satin paint and let em have it. You can leave them in place, sand any scratches and shoot em. IMHO the satin looks better than Suzuki glossy.
post #5 of 8 Old 03-23-2005, 10:01 AM
GB #121
I popped them out and the RH side (throttle side) looked a bit rusty on the inside. Cleaned out the inside of the bars and replaced the ends with new ones from Suzuki.
They didn't cost that much, but big visual improvement. Just need to change the chain now.
I've got some interesting corrosion on the engine casing near the rear brake lever. Dealer has photographed for Suzuki, just need to wait now until they decide if they'll replace it under warranty (although warranty now expired). Will keep you posted.
post #6 of 8 Old 03-24-2005, 09:14 AM
GB #121
No warranty. Will need to rub the casing down and spray paint. It's apparently a very expensive engine casing (compared with other models).
post #7 of 8 Old 03-24-2005, 10:29 AM
thefifthcircle
Throw up some pics of that corrosion if you can! I know others will be interested in preventing it. :wink:
post #8 of 8 Old 03-27-2005, 07:36 AM
GB #121
Sorry, the ends were dumped later that day. If you have any concerns about interior corrosion in the bars, they ends drop out pretty quick with a standard screwdriver. Even if you just wiggle them out a bit to have a quick look.
Cheers.
