Sticky Speedo - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 16 Old 10-07-2004, 11:12 PM Thread Starter
Sticky Speedo
Hey there. My 2004 litre Strom seems to have a sticky speedo pointer. When turning on the ignition, sometimes both pointers do their little dance and sometimes it's just the tach needle only. In those cases the speedo will not indicate speed until you have ridden maybe fifty feet and then it unsticks itself with a vengance. After that it works OK. The sticking is becoming more frequent.
Is this common? Sounds to me like a warranty replacement may be in order. Any feedback? Many thanks.
Jeff
'06 DL-1000
'06 KLX 250S (more fun than people should be allowed to have)
'72 SL-350 K2 (bump start only)
'72 CL-350 (on injured reserve list at this time)
I guess it's better to bend a valve in Missoula than to lose your mind in Bozeman.
-Barb Egan
MWValley is offline
post #2 of 16 Old 10-08-2004, 10:35 AM
Sticky Speedo.
Hi Jeff. If you go over to the DL650 General board you will find a message I posted there in August entitled "Tachometer wins the race", it's about halfway down the page and describes the exact same condition that you have. I've been waiting for someone else to reply there but haven't heard anything yet. My guess is that a number of V-Stroms do this but I happen to be one of those individuals that always has my eyes focused on those guages everytime I start the bike, so the once in a while that it does happen I notice it immediately. I think most riders are looking elsewhere when they start their bikes, which is probably why there is so little feedback on this, so I'm guessing this is pretty much normal.
Dan
trailbuster30 is offline
post #3 of 16 Old 10-08-2004, 07:05 PM
Bob
Never noticed it on my '02, but I'll start watching. If it's an '04 I'd definitely be making a warranty claim before the warranty expires.
Bob
Bob is offline
post #4 of 16 Old 10-10-2004, 09:36 PM
Pauljo
My '03 DL1000 has never done that. I'd try to have it addressed as a warranty issue, particularly since you state that the sticking is becoming more frequent.
post #5 of 16 Old 10-29-2004, 04:43 PM
5-string
Sticky Speedo
Sorry... I've been away for a while and just noticed this thread.
All instrumentation on my DL650 went wacky after about 3000 miles and then, shortly thereafter, they all went dead. Tach and speedo indicated 0 all the time, the fuel gauge always indicated full and the temp guage indicated overheating. My dealer replaced the circuit board, under warranty, and all's well now.
-Bob
post #6 of 16 Old 11-04-2004, 11:36 PM Thread Starter
new inst. panel
Hey Bob,
Thanks for your input. Did the instruments start going wacky a little at time or all at once?
Thanks again,
Jeff
'06 DL-1000
-Barb Egan
MWValley is offline
post #7 of 16 Old 11-15-2004, 09:12 AM
5-string
Hi Jeff,
First the fuel indicator went then temp then speedo. The last thing to go was the tach.
-Bob
post #8 of 16 Old 03-28-2005, 03:06 PM
ArizonaDesertRider's Avatar
Just traded for an 03 1K & the only problem I have found is the tach sitcks. It looks like the neeedle is actually bent down & touching the face. The face also looks kinda melted? Maybe the heat? Will be calling the dealer for replacment tach cost. Any deals on OEM Parts out there.
Bob...
03 DL 1000
03 ST 1300
IBA 16332
ArizonaDesertRider is offline
post #9 of 16 Old 05-06-2005, 08:32 PM
rangoon's Avatar
Hey there -
Found this old thread and wanted to chime in. I noticed my tach needle stick about 1 in every 10 times. Either it won't go all the way around or not at all. Reads fine though.
rangoon is offline
post #10 of 16 Old 05-08-2006, 11:39 PM
Re: Sticky Speedo
Jeff,
Saw your quote in 2004, and my 04 DL650 is developing the same problem. How did you get yours fixed, and what did you/they do to fix it?
I am thinking about a warranty replacement for it. I also lost both low beams (headlight) due to a burnt headlight wire connector. The speedo wires surround this burnt connector (yet to determine whether this could be the cause), or whether it is a faulty instrument circuit board.
Since replacement, has it played up again?
Thanks.
Dave Moore.
Jeff
davemoor650 is offline
