Oem Heated grips - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 03-06-2007, 08:07 PM Thread Starter
Oem Heated grips
Finally got around to installing my grips.... could the instructions be any worse? Another inch or two on the wiring for the plug on wiring harness would have been worth considerable skinned knuckles and frustration. I guess Suzuki would rather it not be too consumer friendly or everyone would do all their own work.
The fairing pieces were fairly easy to work with (you should try a Concours if you want trouble) and I like the plastic rivets.
Has anyone considered using some heatshrink wrap over the connections? They seen to be fairly exposed and could be subject to some corrosion.
The suzuki centerstand was not too difficult.
Next comes the engine guards...
I hope they are more friendly.
Good riding all.
Rick
Tex Rick is offline
post #2 of 7 Old 03-06-2007, 10:28 PM
MZBuckeye's Avatar
I thought the same thing about the cable length and the heatshrink. If you don't route those cables exactly right there's not enough length for lock-to-lock handlebar movement. I haven't added the heatshrink but I might, I dunno, the connectors seemed pretty weather resistant.
1997 Kawasaki ZG1000 Concours, [COLOR="DarkGreen"]GREEN[/COLOR]
Old bikes:
2001 Kawasaki ZRX1200R, [COLOR="Lime"]GREEN[/COLOR], sold
2005 HD FXDCI, sold
2003 Yamaha FZ1, "Bee", sold
2005 Suzuki DL1000, Black, sold
2002 Yamaha FZ1, Silver, sold
1991 Kawasaki Ninja ZX-6D, sold
1982 Honda Sabre 750 V45, sold
MZBuckeye is offline
post #3 of 7 Old 03-07-2007, 10:16 AM
Martin's Avatar
Would it be possible for someone to publish some instructive pix of the correct cable routing? I'm ready to put my grips on but the diagrams in the instructions aren't exactly crystal clear to me.
So far, I've got the old grips off (a couple of squirts of WD-40 under the left grip worked like a champ! thanks to whomever for that great tip!) and have found and unwrapped the pesky stock heated grip connector.
The hardest part so far has been getting the bar-end weights off... had to really yank and wiggle them a lot but eventually they came out in one piece.
- Martin
2019 650X
Martin is offline
post #4 of 7 Old 03-12-2007, 10:48 AM
Martin's Avatar
Thumbs up
Finally finished installing my OEM grips yesterday... The cable routing turned out to be pretty straight-forward... I just followed existing wiring for the most part.
I was a bit apprehensive about how hard it would be to start up the bike after over two months of non-use but it fired right up... just as if I'd been riding the day before (a big thank-you to whomever invented fuel injection).
I turned on the grips and they warmed right up in a couple of minutes... then I was alarmed to feel them cooling down again but I think it was just due to the revs dropping as the engined warmed up. I went for a short ride and the grips got toasty warm again.
I'm happy with the OEM's.
- Martin
2019 650X
Martin is offline
post #5 of 7 Old 03-12-2007, 12:53 PM
Can anyone give a circumference comparison between the stock grips and the OEM grips. I have bigger hands and if the grip is too thin, then hand cramps start to occur. I find the stock unheated grips at the low end of my tolerance threshold. I was curious if the OEM heated grips are a little "fatter".
Does Hot Grips make the OEM grips for Suzuki?
rangoon is offline
post #6 of 7 Old 03-12-2007, 01:22 PM
Some European or Asian company I never head of before makes the Suzuki grips. Hot Grips are heated all the way around, unlike the Suzuki brand.
post #7 of 7 Old 03-12-2007, 07:24 PM
FastEddie's Avatar
Send a message via Yahoo to FastEddie
Bar ends
I took my bar ends off when installing my OEM heated grips. I am glad I didn't unscrew them all the way, or the nut would have fallen off and left me with little recourse.
I installed my handgards, and headlight modulator and center stand while I had the bike apart. As they say, "Let the farkling begin".
06 DL650 "Big Red" brand spanking new
05 DL650 "Big Red" (totalled)
93 DR350S (sold)
"I dreamt I shot an elephant in my pajamas..."
FastEddie is offline
