SW-Motech Center Stand - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 14 Old 03-06-2007, 01:36 PM Thread Starter
I got it in the mail and the lack of real directions isn't a problem for the most part. However, it came with two springs. The pictures only show one. One is two inches in diameter the other is 1.5. They are the same length.
Which one is the right one?
vavision is offline
post #2 of 14 Old 03-06-2007, 01:50 PM
I believe the smaller one fits inside of the larger one. I'm not at home right now, so can't verify that, but I'm fairly sure that's accurate.
John Jenkins
DL1000 K4
jjenkins334 is offline
post #3 of 14 Old 03-06-2007, 01:52 PM
Tomb's Avatar
Send a message via Skype™ to Tomb
Been dealing with the same issue and jjenkins34 is correct.
Tomb is offline
post #4 of 14 Old 03-06-2007, 02:24 PM
The Shepherd's Avatar
Small spring goes inside the big spring, it is a bit of a PITA to install the springs. I took a screwdriver and put the hook parts of the spring around the screwdriver then kind of pried the springs down over that little bit they attach to......it's alot easier to do than explain. It took me three or four tries but they went on there.
Ian
'07 KLX250S - Road
'00 CBR600F4 - Track
"The World is a book, and those who do not travel read only a page" - St. Augustine
The Shepherd is offline
post #5 of 14 Old 03-06-2007, 03:34 PM
BigT's Avatar
Although it may be tempting to try and attach the spring while the stand is down and the bike is sitting on it, you'll never get the spring stretched far enough in that position (its longest travel).
I used a pair of ViseGrips to pull the rear end of the spring into place, and like others have stated, it's a bitch.
-T
2005 VStrom 650 (Blue)
BigT is offline
post #6 of 14 Old 03-07-2007, 11:28 AM
RockyMtnRoadRash's Avatar
A tidbit from another site:
This is for putting the spring on the stand in the up position.
Take a heavy shoelace or similar and tie it to one of the spokes of your rear wheel. Now hook the springs on the front knob, loop the string/lace/whatever through the back hooks of the spring and pull back. The spring will act like a pulley so you get a 2-1 mechanical advantage, which makes pulling the SOB waaaaaay easier.
I'm still waiting for my knuckles to heal from trying to do it with pliers and screwdriver.
-RMRR
'05 DL1000 - Dead at 66K miles.
Nerding it up at Wheelnerds.com
RockyMtnRoadRash is offline
post #7 of 14 Old 03-07-2007, 11:45 AM
or you could always buy a spring puller. They are useless until you need one and then they are golden.
RubberDown is offline
post #8 of 14 Old 03-07-2007, 06:14 PM
zed88's Avatar
Send a message via AIM to zed88
Don't use pliers, as you don't want to knick the spring and give it a eventual failure point.
dl650k5 -fully farkled- 65k miles. Sold but not forgotten
2006 fjr -roadrunner
zed88 is offline
post #9 of 14 Old 03-07-2007, 06:37 PM
MZBuckeye's Avatar
I pulled those springs with a shoelace and they popped right on, easy peasy.
1997 Kawasaki ZG1000 Concours, [COLOR="DarkGreen"]GREEN[/COLOR]
Old bikes:
2001 Kawasaki ZRX1200R, [COLOR="Lime"]GREEN[/COLOR], sold
2005 HD FXDCI, sold
2003 Yamaha FZ1, "Bee", sold
2005 Suzuki DL1000, Black, sold
2002 Yamaha FZ1, Silver, sold
1991 Kawasaki Ninja ZX-6D, sold
1982 Honda Sabre 750 V45, sold
MZBuckeye is offline
post #10 of 14 Old 03-17-2007, 07:51 PM
Clever Title
+1 on shoelace method. After 4 hours of wrestling with those damn springs I finally checked this site and figured out how to do it. Done in less than a minute, on the first try.
Guess I should have been wearing pants...
'86 Suzuki GS450L (redneck-farkled)
'79 Yamaha XS1100 (project bike)
'06 Suzuki DL650 (SW-MOTECH: centerstand, bellypan, crashguards) (3M reflective striping) (Powermadd handguards) (Nelson-Rigg saddlebags and tankbag)
iron_llama is offline
