Running wires for temp control mount for Gerbing clothing - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 09-17-2004, 01:03 AM Thread Starter
I am about to install the Gerbing temp control mount sometime tomorow (Friday, Sept 17th 2004), and I am wondering how the wires can be attached under the fairing ( I plan on mounting the controls on the left side on the black plastic flat area on the far left).
I might be able to figure out how the wires will attach, but not sure if I will be able to twist-tie the wires to other stuff that is there, or do I need some other method: electrical tape (will not last or do the job well), or superglue the wire to the frame (?), kitchen caulk the wire to the frame?
I have a V-Strom 650 if this helps.
'04 Vstrom 650
L12B12E12 is offline
post #2 of 4 Old 09-17-2004, 10:02 AM
Pauljo
I think you are over complicating the process. I just attach the wiring harness they provide to the battery. I let the power receptical stick out under the seat, just in front of where my leg falls when I sit on the bike. Very easy to reach down and plug in or unplug while sitting on the bike. The thermostat cord gets attached to my riding jacket via the belt clip. No need to permanently mount anything - and it works quite well.
post #3 of 4 Old 09-17-2004, 10:46 AM Thread Starter
I have the permanent mount that Gerbing sells ( meant to be permanently mounted on the control area of the bike ). The shop where I bought the Gerbing setup told me to mount the controls on the front of the bike to the left of the speedometer. So I have to drill 4 holes ( dual controls & 2 led readout lights to mount the controls.
I was wondering how to attach the wire that needs to run under the fairing and then under the small black piece that runs from the fairing to the seat.
It looks like there might be some points where I can twist-tie the wire and run it through to under the seat itself?
I might have this figured out before I get answers. So hopefully this will at least be valuable to others someday!
'04 Vstrom 650
post #4 of 4 Old 09-18-2004, 12:25 AM Thread Starter
All went well! I was able to mostly use long lock-ties to attach the gerbing cables at the start to other existing cables that run along the bottom of the fairing. Towards the long black piece that runs below the seat I used some lock-ties holders with sticky backs where you insert the ties.
'04 Vstrom 650
Fitting a 12V accessory outlet - best options DCSF Techy World! GPS, Electronics, etc 37 05-13-2019 09:45 PM
Running wires for accessories. Casper137 General V-Strom Discussion 21 06-07-2017 09:53 PM
Add running lights to your front turn signals for $5-6!! TheGarMan Maintenance, Tech and Products. 13 03-17-2012 07:18 PM
Running wires from lights triman11427 DL650 and DL650A - 2004 to 2011 6 11-11-2011 05:10 PM
Reading Wiring Diagrams middie26 General V-Strom Discussion 16 07-20-2011 04:21 PM
