Madstad problem - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 02-27-2007, 10:17 PM Thread Starter
Longsnowsm's Avatar
Madstad problem
I purchased the Madstad standard windshield mount for my bike. I arrived yesterday, and I tried to install it today. I have run into a problem. I am at the point where you mount the windshield on the new brackets, but the brackets appear to be spaced about 1/4 inch wider than the holes in my windshield. I have tried to see if there is some play in the alignment by loosening the bolts that hold the brackets in place, but there isn't enough there to make a difference. I am having this alignment problem with both the stock windshield and the replacement Givi I just purchased. Has anyone else had a similar issue with the alignment of their Madstad mount? Thanks.
Longsnowsm
Longsnowsm is offline
post #2 of 4 Old 02-27-2007, 10:51 PM
I seemed to have an alignment problem. But I left the Madstad knobs loose. The shield has a curve. I just pressed the curve down and started screws one by one. It aligned up and I tightened it down. I had a similar problem with my FJR and a replacement screen. Warm the shield to room temperature and it flexes more easily.
FJR/V-strom trooper is offline
post #3 of 4 Old 02-28-2007, 12:25 AM Thread Starter
Longsnowsm's Avatar
Thanks Mike! I went back out and "persuaded" the bracket to line up. It is finally mounted. Thanks for the heads up on the mounting technique.
Longsnowsm
post #4 of 4 Old 03-01-2007, 12:08 PM
805gregg's Avatar
I had a problem with my Madsted moving as I rode along, no matter how I tightened them. I stopped at home depot and got 2 star washers, stuck them between the brackets no more movment.
805gregg is offline
