Still not right! - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 19 Old 02-24-2007, 01:18 AM Thread Starter
BigT's Avatar
Still not right!
I finally got my Givi windscreen from TT and installed it on my MadStad, but I'm still getting bashed and beaten to death!
I'm going to try raising the bracket another notch, but if that doesn't work I'm going back to the stock sheild. At least the stock unit doesn't turn into a sail in a cross-wind.
-T
2005 VStrom 650 (Blue)
BigT is offline
post #2 of 19 Old 02-24-2007, 06:29 AM
tmcgee's Avatar
-T
Did you try the Givi by itself? I've got one and the air behind it is TOO still, so I use an MRA with a lip instead. I'm not a fan of that bracket. To me, the bikes that have one resemble those ancient jeeps with flip down windscreens.
tmcgee is offline
post #3 of 19 Old 02-24-2007, 10:49 AM
WeThereYet's Avatar
-T
Oh man, don't tell me that! I should have a Givi here by Wednesday!
WeThereYet is offline
post #4 of 19 Old 02-24-2007, 11:48 AM
MightyShep
You're results may vary. I've got a Givi and MadStad and don't get buffeted at all. Mine is in the lowest setting and tilted in so I'm looking over the shield not through it.
post #5 of 19 Old 02-24-2007, 11:55 AM
I am a newbie to the Wee but I have been riding for 35 or so years now. I, by suggestion of this site put on the Madstad bracket and Givi shield. I works for me. I noticed a big difference in height adjustment and angle. Everytime I go for a ride I try a different adjustment. I have the best adjustment marked that feels the best. I noticed there is alot of air coming up and around the tank. Maybe lower air wings might help.
FJR/V-strom trooper is offline
post #6 of 19 Old 02-24-2007, 08:29 PM Thread Starter
BigT's Avatar
A little more tweaking
With the MadStad in the center position, I find that if I raise the Givi all the way up and lean it all the way back I ride in reasonably clean air. Lots of air, but reduced buffeting.
It's a start.
-T
BigT is offline
post #7 of 19 Old 02-24-2007, 09:32 PM
Crazy Old Guy
fastwally's Avatar
It's a start.
-T
Try the lowest settings with the lean angle back. I keep saying this, higher is not always better.
It's more fun to ride a slow bike fast than to ride a fast bike slow.
K7abs
fastwally is offline
post #8 of 19 Old 02-24-2007, 11:35 PM Thread Starter
BigT's Avatar
How tall are you? I'm 6' 4"
It's different for everyone.
-T
BigT is offline
post #9 of 19 Old 02-25-2007, 04:46 AM
Laava's Avatar
So far I have found that the nicest position is full up and full back. This is not perfect either and changes when Jo is not doing the rear steering:-D
I am going to try and close most of the huge gap at the bottom of the Givi and see what that does. I am not going down the track of having multi different screens. I'm 6' by the way, 183cm or 0.00183km!:mrgreen:
L4 DL1000 Black Strom No3
Laava is offline
post #10 of 19 Old 02-25-2007, 07:58 AM
Heavy's Avatar
Try the old "arm-across-the-chest-at-highway-speeds" trick. I'm running a Givi on the stock mount but with the bottom shimmed out. Most of the air that hits me now comes from down around the tank and up my thighs. I mentioned before that I've actually had rain running UP my visor from it. Maybe you need to look at some vortex generators, I know I am in the spring.
It's a start.
-T
DL1000K6
Heavy is offline
