where is the connector for the hot grips - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 08-16-2003, 11:50 PM Thread Starter
Somebody posted a question about a connector that turned out to be for the hotgrips. I figure it should on the ign circuit and would be good for an electric deer siren I bought. dose any body know where it is
YLO-JKT is offline
post #2 of 3 Old 08-18-2003, 05:37 PM
Way behind the radiator. I found it easier to put a line in off one of the switched ignition lines rather than get at the plug behind the radiator.
tokenboy is offline
post #3 of 3 Old 10-01-2003, 08:18 PM
Woofy
Electrical Outlet for Hot Grips
Yep, it's INconveniently located behind the radiator. When I had my hotgrips installed, I had the dealer take the power of a switched source and put the hi/lo switch facing down, on the underside of the yellow body panel just above the left side passenger footpeg. It's essentially invisible, but can be easily operated while the bike is moving with a simple reach back...not even a stretch and doesn't throw me off balance at all.
New SV Racing Parts Universal Fit Foam Comfort Grips $11.80 SV Racing Parts SV Racing Parts 54 07-14-2017 11:19 AM
Verification of Heated Grips Connector and Wiring Question ajp DL650 and DL650A - 2004 to 2011 7 05-15-2017 10:41 AM
SV Racing Parts Foam Comfort Grips, Universal Fit SV Racing Parts SV Racing Parts 16 07-18-2014 09:59 AM
6$ HEATED GRIPS? Your nuts. T-ville Trooper General V-Strom Discussion 37 02-25-2012 12:16 AM
symantic heated grips over original grips Al Gilliland General V-Strom Discussion 5 11-21-2009 12:37 PM
