Modification of Image Dynamics Headlight Modulator - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 1 Old 02-18-2007, 06:09 PM Thread Starter
Thumbs up Modification of Image Dynamics Headlight Modulator
Hi,
I recently purhcased a fine Image Dynamics headlight modulator, I read all the previous chatter about the "Heads-up" model that used to be available. That was the one that you could manually control whether it's functionality was automatically turned off via ambient light conditions. A quick check with the Multi-Meter shows that in a darkness condition the Photo diode opens up. When light is present, it closes. Merely cutting the light sensor off of the harness and shorting the 2 wires together the device will modulate for as long as you wish, its one less hole you have drill in your bike and one less thing to worry about. I prefer to maintain control of my electronics, If it was dark I think it would drive you crazy anyways, but...if happened to be stopped on the side of the road at night it may be useful to modulate on lo-beam for added visibility along with your emergency flashers. Nevertheless, I thought this simple mod would be appreciated by the electrically challenged who were thinking of buying this modulator instead of the Kisan. Enjoy...Anyone coming up to Americade this June?
Jerry
tractorshaft is offline
