Wiring PIAA lights - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 10 Old 02-10-2007, 08:41 PM Thread Starter
Wiring PIAA lights
I just got some PIAA 1100X Mulit-Fit lights and I am trying to wire them into my bright light...does anyone know an easy way to do this? The wiring looks simple enough if I could just find the bright light wire.
Any suggestions would be appreciated.
Jack Roten
Jack Roten is offline
post #2 of 10 Old 02-10-2007, 09:45 PM
Do you have a test light ??? That is all you should need if I am understanding you correctly.
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
post #3 of 10 Old 02-11-2007, 01:04 AM
What year and size is the bike?
post #4 of 10 Old 02-11-2007, 09:02 AM Thread Starter
My bike is an '05 DL 1000
post #5 of 10 Old 02-11-2007, 09:03 AM Thread Starter
I do not have a test light. If I get one, do you know where to start looking for the high beam wire?
post #6 of 10 Old 02-11-2007, 11:38 AM
Aux lights
"I am trying to wire them into my bright light"
I am also a little confused. You want your hi-beam indicator light to turn on when the PIAAs are on? Do you want the PIAAs to turn on when you turn on the hi-beams?
Is this a kit install, or do you just have the driving lights?
BR650RRrider is offline
post #7 of 10 Old 02-11-2007, 03:36 PM Thread Starter
Sorry for the confusion. I want my PIAA's to come on when I turn on my bright lights. This is what the instructions recommend to do but finding the bright light wire/connnection. etc. is my problem.
Thanks for the help.
post #8 of 10 Old 02-11-2007, 05:46 PM
I only have a diagram for the 650. It's easy enough to check with a voltmeter or even a test light. The ground wire is black with a white stripe. Pull off a headlight socket, turn on the high beam and check which wire provides voltage between it and ground. I'd recommend installing a relay off that wire so you won't be using it to power the headlights and running lights. The wire is barely adequate to provide power for the headlights alone. http://www.fordmuscle.com/archives/2...ting/index.php shows a couple of possibilities with the Bosch relay being a normal situation.
post #9 of 10 Old 02-11-2007, 09:59 PM
The relay is a must
First, the hi-beam wire is the yellow one in the service manual I have for the 1000. It is probably the same for the 650.
A relay is a good idea or you may have trouble. If you want the hi-beam to switch the PIAAs on, just tap into the hi-beam line to switch the relay. A properly sized relay won't use very much power. A dedicated fuse where the power wire leaves the battery would be good too.
I would also recommend a battery voltage gauge if you run other stuff like grip heaters or a vest.
One of the better sources I have found for electric gear: www.Delcity.net
They are cheap, have decent stuff, and quick shipping.
Last thing: I have a set of PIAAs, and they have a warning that the bulbs won't last as long if they are switched on and off a lot. You may want to look for the same warning for yours and adjust your wiring plan?
Brian
post #10 of 10 Old 02-12-2007, 08:53 AM Thread Starter
Thanks to all for the advice. I will get going on it when I return from a business trip this weekend.
I will keep you advised of any issues that I might come up with.
Jack
