Givi engine guards have been updated (pics) - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 15 Old 01-31-2007, 02:27 PM Thread Starter
BigT's Avatar
At least when you order them from Twisted Throttle they are. I don't know about other suppliers. I just got mine this morning and the welded ends have been updated.
-T
Yeah, I've got my work cut out for me today.....
(Actually it won't be that tough).
2005 VStrom 650 (Blue)
BigT is offline
post #2 of 15 Old 01-31-2007, 02:53 PM
Heavy's Avatar
Read the 3 or 4 hundred threads about engine guard rattles before you install them. Must save you asking about it later on.
Ah hell, I'm feeling generous this afternoon....Before you install the joiner/spacer for the cross bars, squooge in a bunch of silicone adhesive, or similar. That way the bars won't vibrate at the join.
DL1000K6
Heavy is offline
post #3 of 15 Old 01-31-2007, 04:24 PM Thread Starter
BigT's Avatar
Thanks for the tip, but I thought I'd read that the new design did away with the rattle.:???: (that's why I posted this)
Oh well, no biggie, I've got some squooge around here somewhere.
-T
BigT is offline
post #4 of 15 Old 01-31-2007, 06:41 PM
I had a rattle develop due to the new improved joint. The bolt backed out one day during a ride and made an awful sound b/w 3000 and 5000 rpms, maybe put some locktite on there to prevent that.
2006 dl1000- grey
"A man is a success if he gets up in the morning and he gets to bed at night, and in between he does what he wants to." - Bob Dylan
"Happiness is nothing more than good health and a bad memory." -Albert Schweitzer
"What we have to learn to do, we learn by doing."- Aristotle
bigtallguy is offline
post #5 of 15 Old 01-31-2007, 07:20 PM
NoVA-Strom's Avatar
Good. Now I know I can order from TT and get the newer design. Maybe that and and SW Motech GPS mount????
R.I.P.
Red 2006 V-Strom 650: "the most shockingly competent machine in the world today"
Alpenkönig (a.k.a. King of the Alps): 2005, 2006
1989 Sportster Bobber Hardtail
1990 Electra Glide with Cop Bags
NoVA-Strom is offline
post #6 of 15 Old 01-31-2007, 09:21 PM Thread Starter
BigT's Avatar
I actually had a problem with the new bolt (upper mount) myself but it didn't back out.. I couldn't get the counter-sink bolt to tighten down all the way, and because I don't read Italian, I didn't know if it was designed that way or not (I'm assuming not). When cranked all the way down it allowed the upper bracket to swivel freely. This didn't seem right so I stuck a flat washer between the two surfaces and tightened it down.
Now all I have to do is buy a shop manual so I can figure out what the torque settings for the bolts I just loostened are.:mrgreen:
-T
BigT is offline
post #7 of 15 Old 01-31-2007, 09:29 PM
Heavy's Avatar
-T
Do a search. There is a free manual for download on .pdf somewhere.
DL1000K6
Heavy is offline
post #8 of 15 Old 01-31-2007, 10:03 PM
per the PAPER manual (I hate online manuals, were you gona wipe your greasy fingers, on the key board?) the torq specs are as follows:
-large, main nut (lower, center of the v) 67.5 lb-ft
-the two sets of smaller nuts on the ends of the bracket: 25.5 lb-ft
You'll want a braker bar for that main one unless you have a really long wrench. Also, at least on the Hepco's they advise you to do one side, then the other to avoid having the engine shift.
Rider33 is offline
post #9 of 15 Old 01-31-2007, 10:07 PM
PS- since the large bolt goes all the way thru the engine, odds are you'll want to keep a wrench on the other side to prevent it from spinning from the look of it.
Rider33 is offline
post #10 of 15 Old 01-31-2007, 10:34 PM Thread Starter
BigT's Avatar
Thank you.
Originally Posted by Rider33 View Post
-the two sets of smaller nuts on the ends of the bracket: 25.5 lb-ft.
That's the only one I need, thank you very much. .
The Givi engine guards don't use the HUGE bolt in the middle (Thank God), just the eight smaller bolts. Still, those eight were a bitch to break loose. I don't have any allen wrench sockets so I had to put an allen wrench on the bolt and whack it with a BFH 'till it broke free.
-T
BigT is offline
