Another heated grip Q (yes I did a search first) - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 01-23-2007, 03:12 PM Thread Starter
BigT's Avatar
Sorry if this is an old topic but I couldn't find the answer when I searched under "Heated Grips".
I've heard a lot of people use a little wire that's found at the front of the bike to run power to their grips, but does that wire have its own relay or do you run a relay *from* that point to the grips?
A better explaination: Since heated grips tend to produce a lot of heat/resistance, it's a good idea to install a relay to protect the switch and the bike's electrical system. When I installed aftermarket grips on my '05KLR 650 I plugged the relay into the existing wire (called the "city light wire") and then on to the switch and grips.
My question is, do you need to install a relay or is a relay already wired into the sytem *before* it reaches the point at which you plug the grips into it?
And/or if I run the OEM ($$$) heated grips do they have a built-in relay in them that negates the need for a separate relay?
Was that clear enough?
-T
BigT is offline
post #2 of 8 Old 01-23-2007, 03:52 PM
SCraig's Avatar
The factory connector is connected in parallel with the front brake light circuit before the switch. There is no relay in the circuit. My Symtec grip heaters draw less than 3 amps for the pair on high so there is really no need for one.
Scott Craig - Nashville, TN
SCraig is offline
post #3 of 8 Old 01-23-2007, 04:05 PM
That connector is, after all, designed and placed to feed Suzuki's heated grips.
post #4 of 8 Old 01-23-2007, 04:19 PM
MATTMAN's Avatar
I use a separate relay and use the OEM grip heater wire to pull my relay in, the wire should work just fine by itself.
650...Anything more than a handfull is wasted
MATTMAN is offline
post #5 of 8 Old 01-23-2007, 06:17 PM Thread Starter
BigT's Avatar
Ah haaa..
That I did not know... Thanks for the tip.
-T
BigT is offline
post #6 of 8 Old 07-10-2007, 12:38 PM
savvy's Avatar
Can anyone tell me the easiest way to find the wire to hook up the power wire for the symtec heated grips? i was going to run another lead from the battery but having it turned off when the ignition is off would be better i think
thanks
mike
DL1000 K3
author of future books, "Stuck in Pickering" and "Only Cowards Stay Married"
savvy is offline
post #7 of 8 Old 07-10-2007, 12:47 PM
The horn lead which will plug into the stock heated grips connector is part number 36852-06G00. Do a search on that number and you'll get lots of posts on finding and using the connector behind the radiator.
post #8 of 8 Old 07-10-2007, 01:43 PM
savvy's Avatar
thanks Pat. i'll do that.
DL1000 K3
savvy is offline
