Fuse block & Master Ground - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 01-18-2007, 11:55 PM Thread Starter
USMC V-STROMMER's Avatar
I received and installed my fuse block & master ground block from "Electrical Connections" today. I wanted it to add a reliable connection point for my 12V power outlet and possibly some heated gloves or whatever else I decide on sometime down the road. Everything arrived well packaged and the instructions were well put together. I also used the wiring diagram on the other V-Strom forum as a reference. The install took about 2 hours and went rather smoothly. I took pictures along the way if anyone is interested. I'm just not in the mood to download them right now for posting but hope to get to it this weekend.
Shiny side up, Rubber side down!
DL650K5/Red
Semper Fi!
USMC V-STROMMER is offline
post #2 of 3 Old 01-19-2007, 03:17 PM
Tollster's Avatar
We all love pictures...they are worth a thousand words!
Tollster is offline
post #3 of 3 Old 01-19-2007, 07:28 PM Thread Starter
Wink
Here are the photos:
I drilled through the tupperware to mount all items with nuts & bolts using a washer & lock washer on each side of the plastic. Hopefully nothing vibrates loose. The side panel was an easy removal. Just 3 of the plastic circular clip things, one bolt, and the removal of the rear rack. I guess I should add that it all went back together easily as well and surprisingly, I had no "spare parts" left over.
DL650K5/Red
Semper Fi!
