Corbin seat install question - the rear bracket... - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 01-14-2007, 06:24 PM Thread Starter
Ajaxthedog89's Avatar
If you own a Corbin seat you probably know the answer to this question.
I got my new seat yesterday, no installation instructions at all and nothing I can see on the website about this. It had no rear seat pan bracket so I took that off my stock seat and bolted it on. Seat still won't lock down though, and it looks like it needs a hole drilled in the seat pan in the center of the bracket to make room for the thick alignment pin on the frame side to fit in it.
OK, needing the stock bracket is one thing but before I start drilling holes in my new seat maybe one of you geniuses with this seat could tell me what you have on yours. I don't think it matters but it is a 650. Thanks.
Current Stable:
98 Kaw KLX300R
73 Yam DT360
06 Suz 650 V-Strom
07 BMW R1200RT
Any bike is better than no bike. All bikes are good. Even scooters.
Ajaxthedog89 is offline
post #2 of 7 Old 01-14-2007, 07:37 PM
MightyShep
I added a Corbin. I mounted the bracket from the Stock seat and it locked right into place. Have you tried taking it off and reinstalling it?
post #3 of 7 Old 01-14-2007, 08:27 PM Thread Starter
No hole?
Really? Mine just won't lock in. Is there a recess or hole in your Corbin where the bracket has that big hole in the middle?
Current Stable:
98 Kaw KLX300R
73 Yam DT360
06 Suz 650 V-Strom
07 BMW R1200RT
post #4 of 7 Old 01-14-2007, 08:36 PM
rxcoop's Avatar
i had to shim mine down with a couple washers then it snapped right in....may hafta experiment to get the thickness correct. other then the, enjoy the seat....makes a wonderful difference <tho i dont wanna start a "corbin vs" thread>?
Bill Cooper (dba "drug dawg")
1994 Mazda Miata M-edition
2012 VStrom 650A
<applicant for "Official Pharmacist of the Rock and Roll Hall of Fame" (R)>
rxcoop is offline
post #5 of 7 Old 01-14-2007, 11:38 PM Thread Starter
Washers! I bet that will work for me, thanks for the advice.
Current Stable:
98 Kaw KLX300R
73 Yam DT360
06 Suz 650 V-Strom
07 BMW R1200RT
post #6 of 7 Old 01-15-2007, 08:42 AM
Crazy Old Guy
fastwally's Avatar
Have you tried putting the seat on and then setting on it to lock it in? If it will, you probably won't need the washers after you get some wear on the seat.
It's more fun to ride a slow bike fast than to ride a fast bike slow.
K7abs
fastwally is offline
post #7 of 7 Old 01-15-2007, 09:06 AM
aps45819's Avatar
Mine snapped right on after swapping out the mounts (as described in the instructions), but it's about 1/4 inch to long. The flap covering the backrest hole won't fit under the edge of the luggage rack
'06 DL1000 new on 1/13/06
The difference between driving a car and climbing onto a motorcycle is the difference between watching TV and actually living your life.
aps45819 is offline
