12 Volt Socket - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 49 Old 01-11-2007, 12:56 PM Thread Starter
12 Volt Socket
Where are you guys and gals mounting 12 volt sockets? I'm tossing around a couple of options i.e. loom for brake lines, drill into fairing, make a dash. Before I go ahead and do this I thought I would ask for pictures or descriptions of what some of you have done. Come on now I know I'm not the only to put one on so pony up!!
Thanks,
Travis
'sota Strom is offline
post #2 of 49 Old 01-11-2007, 01:12 PM
Contact Powerlet. they have a kit that goes into the left fairing. I have their stuff on my FJR. High qualityand all the things you need to hook up all your electrics.
FJR/V-strom trooper is offline
post #3 of 49 Old 01-11-2007, 02:59 PM
nvr2old's Avatar
Got this from Walmart for $12.95. It's the same waterproof one as sold in marine stores for $29.
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
for the safety of existence.
nvr2old is online now
post #4 of 49 Old 01-11-2007, 04:40 PM Thread Starter
NVR2OLD,
Have you run with anything plugged into the outlet that is mounted on your handle bars? Where there any issues?
This is one location I considered myself but was not sure how this will work with a bar mounted GPS.
T
post #5 of 49 Old 01-11-2007, 06:19 PM
Darryl's Avatar
Did the same thing as NVR2old
Darryl is offline
post #6 of 49 Old 01-11-2007, 06:31 PM
STrider's Avatar
I mounted a Powerlet into the Tupperware just below my left leg to run my electric vest. It's directly wired into the battery so I can also run a Battery Tender into it, or a small compressor out of it. Yes, it's fused.
I'm working on a small (tiny) dash to mount 2 Powerlets that will go between the handlebar mounts. I'm going to fabricate it out of sheet metal. It will power the XM and the GPS.
It's not the destination that matters...
'04 ST1300
'07 Wee
STrider is offline
post #7 of 49 Old 01-11-2007, 07:24 PM
nvr2old's Avatar
Just installed it last week. I don't forsee any issues with it, but have only run my pump to test it. So far I just plan to use it for the pump and charging my cell phone on multi day trips. I also wired in driving lights and heated grips thru a separate fuse box, powered by a relay.
DL-1000 L8
DL-650 K5 red(122K)
09 DRZ400
post #8 of 49 Old 01-11-2007, 07:44 PM
Wee_Willie's Avatar
Thanks,
Travis
Just got mine. About to fill a snowy winter day (25 minutes) with the installation.
http://powerletproducts.com/products/suzuki_vstrom.php
Willie
[url]http://www.flickr.com/photos/[email protected]/[/url]
IBA#27466
2007 Suzuki GSF1250K7 Bandit - Black of course!
2006 Suzuki DL650K6 - Alaska and back July/Aug 2007
1978 Yamaha SR500E - Frame up restoration in progress
1968 Yamaha DT1 Shorttracker / "Bargain" Craigslist find... yeah, right
Wee_Willie is offline
post #9 of 49 Old 01-11-2007, 09:20 PM
nighthawk is offline
post #10 of 49 Old 01-11-2007, 09:49 PM Thread Starter
Nightwawk
Did you move your brake lines? They are not clear in the pic. How did you fasten the socket?
TIA,
T
