Inexpensive Rear Spring - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 7 Old 01-08-2007, 12:33 PM Thread Starter
Involute's Avatar
Relatively Inexpensive Rear Spring
http://www.hrpworld.com/HypercoSprin...ction=category
I bought a Rear Spring for my FZ-1 from these guys and they were great to work with. $70 +/- $5 for a proper rate rear spring is a pretty good deal IMO. I’d like to do the same for my DL650 but I don’t know off hand what size and rate I need. I had the benefit of having a buddy with the same FZ as me that weighed the same and had already bought one for himself so it was a no brainer. I ordered what he ordered.
The Strom is another story so I have a few questions I’d like to ask:
Does anyone know for sure what the Inside Diameter and Free Length the rear spring needs is on the 650?
Any suggestions as to what Spring Rate a “Larger Fellow” such as myself might need? I tip the scale at 260.
I’d ask the people at the site above but they are a car shop so they’ll know less than me. I'm guessing it'll be either 2.25" or 60mm x 7.0 as the 2.50" ID Springs are not rated very high.
Worse case scenario is I remove the existing spring to measure myself and then let the bike sit until the new one arrives. I’m just the type that freaks out when I have a torn apart bike in the garage for more than a day.
2011 Wee
Involute is offline
post #2 of 7 Old 01-08-2007, 02:46 PM
Heavy's Avatar
Why not just go to Wilbers?
Around $100.00 and you'll get the right thing, first try.
http://www.wilbersusa.com/wilbers/products.htm
DL1000K6
Heavy is offline
post #3 of 7 Old 01-08-2007, 03:06 PM Thread Starter
Involute's Avatar
For a few reasons actually.
First and foremost, I’m cheap! BTW, Wilbers is actually $110.
Second, I’m under the impression that Wilbers only has one rate to choose from and I don’t know what it is.
Did I mention that I’m cheap?
2011 Wee
Involute is offline
post #4 of 7 Old 01-08-2007, 04:08 PM
Heavy's Avatar
You really are cheap if $30.00 is a deal breaker, even if the extra $30.00 means you get something that is correct for the application. :rolleyes:
Do some searching, you'll find that the Wilbers spring is plenty strong for you. I haven't installed mine yet but most guys are saying they use zero preload with the Wilbers piece and the stock shock.
WILBERS - Info <[email protected]> wrote:
Replacement rear spring is $ 116.00 shipped to you.
The new spring is approx. 23% stronger then the OEM.
OEM rate is 84 Nmm new spring is 103 Nmm.
Item is in stock, call with your credit card.
Regards
Klaus Huenecke
DL1000K6
Heavy is offline
post #5 of 7 Old 01-08-2007, 04:33 PM Thread Starter
Involute's Avatar
I may be cheap but at least I can add and subtract. Itís a $40 difference (insert Razz Smiley here).
Just busting your balls man. I appreciate your help.
I may very well go the Wilbers route but if I can save $40 (36%) Iím all for it. Itís another night in a CHEAP Motel while Iím on the road.
Springs are Springs IMO. As long as the Sizes are the same the application is correct if I get the proper Spring Rate. The Spring has no idea if it's in a Bike or a Blender.
2011 Wee
Involute is offline
post #6 of 7 Old 01-08-2007, 07:53 PM
Heavy's Avatar
OK, if we want to get picky about it. The spring is actually $106.00 but he included the $10.00 for shipping in the total amount. (razz smiliey inserted :-D )
I understand that a spring is a hunk of metal and won't know if its in a V-Strom or a space ship, but your "Iím just the type that freaks out when I have a torn apart bike in the garage for more than a day." comment makes one think you might be better off just ordering the spring from Wilbers. Its all good and I understand about saving a few bucks but I'd hate to see your wife come on here and post about how your head exploded because your Wee was apart in the garage for 2 weeks because your experimental spring didn't fit.
DL1000K6
Heavy is offline
post #7 of 7 Old 01-08-2007, 08:44 PM Thread Starter
Involute's Avatar
I understand that a spring is a hunk of metal and won't know if its in a V-Strom or a space ship, but your "I’m just the type that freaks out when I have a torn apart bike in the garage for more than a day." comment makes one think you might be better off just ordering the spring from Wilbers. Its all good and I understand about saving a few bucks but I'd hate to see your wife come on here and post about how your head exploded because your Wee was apart in the garage for 2 weeks because your experimental spring didn't fit.
And they say Canucks have no sense of humor.
2011 Wee
Involute is offline
