Dynojet map ... 02-03 DL1000 - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 9 Old 01-02-2007, 01:35 PM Thread Starter
I recently had my 02 DL1000 dyno tuned at the local Harley dealer (with a dynojet dyno) they are a authorized dealer with excellent techs ... anyway I thought I would share ... Here is the map using a power commander 3 (non usb) for those of you using a power commander USB .... just manually plug in the numbers in 500rpm increments ... leave "O" at 250rpm increments The specs are ...
Secondaries removed
air box snorklel removed
stock air filter
stock exhaust
Generally speaking ... if you look at the map ... the bike was running rich and flat .... now the power feels juicy and the fuel milege went way up
I ride the bike at between 500 - 2500 ft elevation ... I hope this helps some of you
File Type: zip DL1000 Dyno Tuned Secondaries and Snorkle Removed.zip (579 Bytes, 113 views)
freewheeler is offline
post #2 of 9 Old 01-02-2007, 03:36 PM
OleGrumpy's Avatar
I just pull my PowerCommander out. I had my TB's re-sync'ed and I no longer need the PC.
My post: https://stromtrooper.com/forums/showthread.php?t=8462
OleGrumpy is offline
post #3 of 9 Old 01-07-2007, 08:00 PM Thread Starter
Secondaries removed
stock air filter
stock exhaust
Update ...
Today I put on 227 miles in varied terrain from main hi speed roads to unimproved dirt and gravel roads ... elevation changes from 750' to 2500'
ambeint air temp ranged from 41 degree F. to 34 degree F. ... Zeroed my odo at fuel up this morning ... went excatly 200 miles and filled up again ...
4.5 gal ... the equates to 44.44 miles per Gal ... Bottom line ... I'm really happy with the Dyno tune results ... power feels great ... mileage is the best it has ever been ... with the same type of riding ... before the dyno tune ... I would get somewhere in the mid 30's for mileage ...
post #4 of 9 Old 01-08-2007, 07:24 PM
OleGrumpy,
Can you take some photos of what you are talking about? I am not sure about the rubbers you are talking about. I am also having problems with the throttle so I am curious if it's similar to your problem.
Thanks in advance
Kevin
AZTrooper is offline
post #5 of 9 Old 01-10-2007, 08:21 PM
OleGrumpy's Avatar
I don't have any pictures but, the throttle bodies are held in place on the intakes by large, heavy rubber boots. The boots are about 2-2.5 inches in dia. and about 2 inches high (I am going from memory here.)There is an adjustable clamp on the boot that, when adjusted, tightens around the boot and secures the throttle body in place. I saw somewhere on the Internet, a PDF copy of the DL1000 shop manual. I know they have an exploded diagram of the throttle bodies and would give you a better idea as to how they attach.
post #6 of 9 Old 01-11-2007, 12:16 PM
OleGrumpy's Avatar
post #7 of 9 Old 01-11-2007, 09:42 PM
Heavy's Avatar
Are you talking about #17?
DL1000K6
Heavy is offline
post #8 of 9 Old 01-12-2007, 08:36 PM
Good so far
I downloaded your map and put it in my PCIII USB. So far, so good. Seems to be smooth. And it's a lot leaner than the map I was running. I will need to test it more to be usre. Will try to remember to post results.
Thank you!!!
ejy712 is offline
post #9 of 9 Old 04-13-2014, 09:35 PM
vstrom_scott's Avatar
anybody have this as a .djm or .pcv format?
I can't read the map to see what the increment adjustments are but I've got an '02 and I'd like to give this one a try. My PCV has an import feature for .djm to convert those, but not for .map files.
vstrom_scott is offline
