Hyper-lites + BackOFF Wig Wag - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 12 Old 01-01-2007, 07:45 PM Thread Starter
bobosmite's Avatar
After installing a set of Hyper-lites, my friend commented that it wasn't as dramatic as he expected. So, I added a BackOFF Wig Wag and now it's a lightshow.
Here are two videos, one close up and one from a distance.
http://www.youtube.com/watch?v=-KYcPag6GbQ
http://www.youtube.com/watch?v=in_qPAF564E
2014 Suzuki DL1000
SEARCH is your FRIEND
bobosmite is offline
post #2 of 12 Old 01-02-2007, 02:09 AM
Tis better to be seen and not hurt.
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
post #3 of 12 Old 01-02-2007, 03:13 AM
C&CFunFactory's Avatar
Send a message via AIM to C&CFunFactory
At the risk of sounding like a total wuss.... Is that legal? I know the hyperlites are but the wig-wag of the tail light... looks awesome by the way.
C&CFunFactory is offline
post #4 of 12 Old 01-02-2007, 04:37 AM
zed88's Avatar
Send a message via AIM to zed88
I'm a visibility nut myself but I'd defintley have reservations about installing a wigwag on your taillight. Its very eye catching and I defintley think you'll get attention but not all of it may be positive. Its distracting and I bet people will be focusing on your rear end and not on traffic.
Its the same concept as people plowing into the back of police cruisers when they pull over with their lights on.
Have you thought about putting brake lights on your side cases?
dl650k5 -fully farkled- 65k miles. Sold but not forgotten
2006 fjr -roadrunner
zed88 is offline
post #5 of 12 Old 01-02-2007, 06:05 AM
Packa-strom's Avatar
The Hyper lights look pretty good actually.
For reference: the wig wags, which the name would imply are shown in these videos as having the "left then right" flashing.
http://www.signaldynamics.com/images...wag_mode01.gif
Packa-strom is offline
post #6 of 12 Old 01-02-2007, 10:25 AM Thread Starter
bobosmite's Avatar
If I didn't use the side cases so much, it would be a good idea. I like the quick-disconnect and sometimes ride without them.
2014 Suzuki DL1000
post #7 of 12 Old 01-02-2007, 03:45 PM
was it difficult to wire both the backoff wig/wag and the hyperlites? I've already got the Signal Dynamics unit installed & would like to add the hyperlites to it.. where would I cut-in to the existing wiring?
John
04 Blue DL650 with some add-ons
and scratches...
p7m8jg is offline
post #8 of 12 Old 01-02-2007, 05:40 PM Thread Starter
bobosmite's Avatar
The Hyper-lites were installed first and I noticed that it only controlled the LEDs. They connected to the tail light only to pass voltage to the bulbs. So, I cut the hot wires from the bulbs and installed the BackOFF module to the tail lights.
If you want to add Hyper-lites, just tap anywhere on the brake wire. It's like a Y-connection. Voltage from the brake wire feeds the BackOFF and tail light one side and it feeds the Hyper-lites and LEDs on the other side.
I think that makes sense the way I wrote it?
2014 Suzuki DL1000
post #9 of 12 Old 11-11-2007, 12:52 AM
Hey
I know this is an old thread, but I just got the wig-wag and have been trying to figure out the best place to splice it in. can I get away without taking off the plastic, or do I pretty much have to get the whole tail end taken apart?
thanks! (no hyperlites, not yet anyway)
crazyrussian is offline
post #10 of 12 Old 11-12-2007, 03:14 PM Thread Starter
bobosmite's Avatar
I took the back end off and attempted to stick the BackOFF brick to the plastic tail section. It quickly vibrated loose and now it sits in the far back end of the tray under the seat. Taking off the tail section really isn't that bad except for the two side screws behind the mufflers. I'd do it just to be sure you're cutting the correct wire.
2014 Suzuki DL1000
