Want to replace aluminium bolts with steel - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 15 Old 01-01-2007, 07:13 PM Thread Starter
bobosmite's Avatar
Does anyone know a source for steel bolts? Specifically, I want to replace the bolts that came with the Givi crash guards. I have to loosen them every time I take off the fairing panels and the hex heads are starting to get worn. This place http://www.boltmotorcyclehardware.com/ has a bolt assortment kit, but it's a bit more than I need. Plus the Givi bolts are slightly longer (8mmx35) and probably don't come in the assortment.
2014 Suzuki DL1000
SEARCH is your FRIEND
bobosmite is offline
post #2 of 15 Old 01-01-2007, 07:20 PM
You'll have to know what sizes you need or bring the old ones to match up, but I've found stainless steel (what I'd recommend, you didn't specify) and galvanized, yes metric, in the little drawers at Lowe's, True Value, etc.
icanfixthat is offline
post #3 of 15 Old 01-01-2007, 08:14 PM
SCraig's Avatar
I found them locally. Don't know where you are but check the Yellow Pages for "Bolt and Screw". We have a couple of places here and if you can't find them I can get them for you. Lowes does have metric stainless steel bolts (as icanfixthat mentioned, that's what you want) but I don't know if they have the correct lengths or not.
Scott Craig - Nashville, TN
SCraig is offline
post #4 of 15 Old 01-02-2007, 02:05 AM
Go for the stainless steel, you won't regret it. The supplied bolts fron Givi will snap off( this I know).
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
post #5 of 15 Old 01-02-2007, 03:13 AM
Clever Title
I'm thinking of doing this as well, but I'm wondering if anyone's had any corrosion issues with this? I'm away from my bike right now, so I'm can't make sure that the parts I'm thinking of are aluminum, but wouldn't a steel bolt threaded into aluminum corrode rather quickly?
Guess I should have been wearing pants...
'86 Suzuki GS450L (redneck-farkled)
'79 Yamaha XS1100 (project bike)
'06 Suzuki DL650 (SW-MOTECH: centerstand, bellypan, crashguards) (3M reflective striping) (Powermadd handguards) (Nelson-Rigg saddlebags and tankbag)
iron_llama is offline
post #6 of 15 Old 01-02-2007, 09:44 AM
Jammerjay
I think you are thinking of galvanic corrosion, which typically needs some type of electrical energy source between the 2 materials, or one may be the grounding source which would lead to eventual corrosion. I would recommend the use of anti seize and be very sure not to over torque. The threads on the steel will not stretch at the required torque as aluminum to aluminum, all the stretching will be the aluminum. However, if the female thread is steel, its not really a concern.
post #7 of 15 Old 01-02-2007, 10:33 AM
tmcgee's Avatar
These guys are local to me, but are a mail order supplier with an excellent selection of metric stainless steel hardware. They used to have a retail counter, and you can still pick up your orders locally. (Weymouth, MA on Rte. 3A, just south of QuinZy)
http://www.boltdepot.com
tmcgee is offline
post #8 of 15 Old 01-02-2007, 11:02 AM
I take it the aluminum bolts thing is a joke. Some people might not understand the Givi bolts are steel but just too low a grade. Old japanese bikes had soft galvanized steel phillips head case screws that loved to get stuck. Various manufactures made stainless allen head replacement sets. Stainless comes in various grades so can be too soft also.
post #9 of 15 Old 01-02-2007, 11:36 AM Thread Starter
bobosmite's Avatar
Talking
Those Givi bolts are like trying to wrench a block of butter they're so soft. As long as you're careful and don't over-torque, they're probably just fine. But, I've turned them at least 10 times and one of them isn't looking too healthy. It's good to have spares because it's a pretty darn important bolt and I already lost the one spare that comes with it (the bolt that joins the two halves).
2014 Suzuki DL1000
post #10 of 15 Old 01-02-2007, 05:01 PM
RichDesmond's Avatar
My local ACE/TrueValue hardware store has a very good assortment of metric bolts. A good online source is www.boltdepot.com.
Rich Desmond
RichDesmond is offline
