Stebel horn on Pat Walsh bars. - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 16 Old 12-11-2006, 11:01 AM Thread Starter
bill l's Avatar
Lightbulb Stebel horn on Pat Walsh bars.
I have no way to post pictures but here goes anyway. For those of you familiar with PW bars: I drilled the right side accessory bracket for the horn mounting bolt and mounted the Stebel on the inside of the right bar. I had previously removed the right side bar and drilled holes for the wire to run inside the bar. One hole in the bar next to the top of the horn and one hole in the bar end that bolts just below the tank. I pulled 16AWG through the bar, installed grommets and sealed the whole thing in place with Goop. There are pluggable connectors on both ends of the wire for ease of disassembly for removal of bars or horn. It's a clean install and worth the effort.
64 Hon cub 50, 67 Hon trail 90, 68 Yam 180 twin, 66 Hon 305 dream, 71 Yam 175 enduro, 73 Yam tx500, 70 Hon sl100, 75 Hon xl250, 79 Yam sr500 , 95 Kaw en500, 98 Hon cb750, 02 Yam fz1, 06 Suz dl650, 07 Hon ST1300
Avatar:
https://www.stromtrooper.com/forums/a...4&d=1170279743
bill l is offline
post #2 of 16 Old 12-11-2006, 12:34 PM
bobosmite's Avatar
Does anyone have good pics of this mounted on a DL1K? I'd like to get it inside the fairing, but all I've seen are are DL650 installation pics.
2014 Suzuki DL1000
SEARCH is your FRIEND
bobosmite is offline
post #3 of 16 Old 12-11-2006, 08:25 PM
Roo
Stebel horn
Roo here greetings :-D I also have a Stebel horn and a photo would be great to get a second idea of mounting the horn
Roo is offline
post #4 of 16 Old 12-11-2006, 08:30 PM
Forum Admin
fatalerror's Avatar
Location: South West Florida, previously, South Africa.
Iv'e done that. Here ya go!
http://picasaweb.google.com/raydebruyn/StebelHorn
edit: there ya go, made it public.
fatalerror is offline
post #5 of 16 Old 12-11-2006, 08:32 PM
Heavy's Avatar
Need to allow us in...
Forbidden
Your client does not have permission to get URL / from this server
DL1000K6
Heavy is offline
post #6 of 16 Old 12-11-2006, 08:35 PM
Forum Admin
fatalerror's Avatar
try again on the new link bud.
post #7 of 16 Old 12-11-2006, 08:38 PM
Heavy's Avatar
Slick, link works now.
You might check the mounting instructions. I think they suggest a more upright mounting position.
DL1000K6
Heavy is offline
post #8 of 16 Old 12-11-2006, 09:00 PM
Forum Admin
fatalerror's Avatar
Yea, they do, but I have had zero trouble with water intrusion, even under pressure wash. [See the little pipe by the red wire?]
Works ok for me
post #9 of 16 Old 12-12-2006, 09:16 PM
Roo
Stebel Horn
Roo here Looks good the way the Horn was fitted , however i never received a wiring diagram could somebody help me please
Roo is offline
post #10 of 16 Old 12-12-2006, 10:54 PM
The mounting position(upright) could have something to do with integrity of internal parts over time and wear and tear while in operation in that position. The water factor can be covered with the use of some surgical tubing no matter what the position.
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
