Symtec grip heaters - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 28 Old 12-10-2006, 01:29 AM Thread Starter
Symtec grip heaters
Hi all, need some input about Symtec grip heaters. They seem like a decent product for their intended use so here is what I am wondering. Has anyone tried mounting the heaters on the stock grips and then covering them with grip puppies. I have been thinking this would be an easy install if things fit. Any comments or advice would be welcomed. Thanks in advance.
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
post #2 of 28 Old 12-10-2006, 08:26 AM
Never done it that way. It might get too warm though. I took off the stock grips and put them on the bars then put back on Pro Grip 714 which seem to work well and get warm fairly soon. You could call the company and ask about it if you can find a number for the manufacturer.
JDP
jdpower is offline
post #3 of 28 Old 12-10-2006, 10:11 AM
Heavy's Avatar
I'm running the Symtecs and the only thing I'd suggest is to consider wiring them in series, rather than parallel. For me, the low setting is almost too warm and I usually have to cycle the switch to be comfortable. I've never used the high setting but I bet it would melt the grips or grip puppies. I picked up some thin pipe insulating tape at CTC and put it on the clutch side of the handlebar before I put the heater on. No problems with the throttle grip being warmer than the clutch.
DL1000K6
Heavy is offline
post #4 of 28 Old 12-10-2006, 11:49 AM
StarWatcher's Avatar
Saw a post over on twtex.com where someone did this in the past day or two. One of the questions that came up is that since the connecting wires would always be flexing as you rotate the throttle, how much more likely are they to break?
--Mike
DL650K6 (Red)
StarWatcher is offline
post #5 of 28 Old 12-10-2006, 01:28 PM
Don't worry about it. There are many wires moving every time the handlebars are moved. Just don't run anything so tight it kinks when moved.
post #6 of 28 Old 12-10-2006, 02:02 PM
No longer riding.
handyhiker's Avatar
Question Help with install
I've got a set of these to install on my 07 1000. Did you tie into the harness where the factory ones do or did you go back to the battery area?
Totaled on June 9 2012 08 Victory Vision Tour Premium.
No longer riding due to injuries on June 9 2012.
handyhiker is offline
post #7 of 28 Old 12-10-2006, 02:16 PM
That's exactly the way I installed them as I wanted larger diameter grips anyway. While I never used them in extremely cold conditions, I found that the Hi was too hot and even the Lo was too hot at times (handlebar mounted Hi-off-Lo switch). It was nice to be able to warm up your hands on demand. The heating elements were equal out-put (non-mc specific) and using a heat-troller with these for infinitely variable heat would be ideal.
Silver 04 DL650K4 V-strom
GetFuzzy is offline
post #8 of 28 Old 12-10-2006, 09:56 PM Thread Starter
Thanks guys, nice to know I am on the right track. Heavy, I already was considering wiring in series as you suggested that when we met for coffee on your trip. Fuzzy, have you done much riding lately with the grips ?? Did you wire in series or parallel ?? The heat troller also sounds like a good idea to consider.
05 / 650 in blue
75/Suzuki 125 RV
post #9 of 28 Old 12-11-2006, 03:02 PM
I used a horn lead and plugged that into the heated grip plug (taped to the radiator). Haven't ridden since Sept. as I'm recovering from a crash and still don't know if bike is a write-off, so may not order a heat-troller after all. I don't know what the recommendations are for their installation, but would assume that it would replace the hi-off-lo switch.
GetFuzzy is offline
post #10 of 28 Old 12-11-2006, 06:49 PM
Mine are set up the same way with the grip puppies. I have them run in Parallel. I have used them down to about 28 degrees so far. They work well, I don't feel that I would want them much warmer. I had them running on a warm day and they about cooked my hands. I find I run them about 20 minutes to get everything nice and warm and them shut them down and the residual heat is great for another half hour.
My wires are run well with enough left to cover the movement, no issues. I located the switch up by the gauges. These are a great addition for those real cold days.
NYrider67 is offline
