HID VVME Install - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 10-31-2012, 01:00 PM Thread Starter
nobie381's Avatar
Smile HID VVME Install
So I am very excited, my VVME HID kit came in a today early and didn't get held up at all by Sandy.
So I was trying to come up with a plan here at work so my life will be easier this weekend when I install the lights.
This is not a motorcycle plug and kit being these are made for cars but I was going to cut off the battery leds (combining the 2 grounds together into one wire and running the negative and postive wires to my PC-8 (By doing this I can cut off the fuse on the power cable.)
Here is what I think I need:
- longer bolts with nuts in case I want to mount the ballasts like johnofchar did on vstrom message board
- 3m two sided tape in case I use that as my ballast mounting option.
- extra 14g wire to extend the wires to the PC-8
- heat shielding for the wire (I have been treading the wires on the side of the bike instead of under the tank.)
Let me know if I am missing anything, thanks in advance.
2011 SUZUKI DL650 V-Strom ABS/Pearl Mirage White
Farkles: Aprilia Tuono mirrors / Pat Walsh Design Super Brace / DL1000 Seat / Givi engine guards / RR Peg Lowering Kit / Madstad Bkt w/ OEM or Givi Shield / PL532 & E41nn / SW-Motech CenterStand / EB PC-8 - 2x power outlets - Datel Voltmeter - Stebel Horn with PWD setup - Digital Slim H4-3(9003) Bi-Xenon HID - 1157 LED Brake lights
Shiro Nakama Hachi [SIGPIC][/SIGPIC]
nobie381 is offline
post #2 of 5 Old 10-31-2012, 02:02 PM
Texas Oilman's Avatar
I would advise using another secondary mounting device like zip ties to go with double sided tape for your ballasts. He vibration (especially on a motorcycle) will shake them off easily. I mounted mine back to back on the top middle of he headlight frame so as not to interfere with steering and kept in a cool place.
Steering is locked in this pic fyi
Texas Oilman is offline
post #3 of 5 Old 10-31-2012, 03:28 PM Thread Starter
nobie381's Avatar
Well after reading some more it looks like I will need to do the second install where you drill into the sub frame becuase I have the 2011 ABS model. question for someone who has done this: what kindof spacers did you use and what size screws etc? I am alittle worried about drilling the sub frame...
nobie381 is offline
post #4 of 5 Old 10-31-2012, 03:58 PM
3M Duo-Lock works fine. I had it on the '07. I did drill through the stiffening web on the front frame of the Glee to mount ballasts where John did on his Wee. The clearance problem he had isn't a problem on the Glee.
post #5 of 5 Old 11-10-2012, 04:08 PM
Add another person to the list of VVME HID users. With Nobie's help I got mine installed this morning (and my PC-8 last weekend also with his help). I'm on a 2011 ABS so I also did the "drill the sub frame" to connect the ballasts up inside the front end. Install turned out pretty clean, I'm quite happy with it.
I think we might do a night ride tonight just to test them out.
-Cambion
2018 V-Strom 1000XT
2011 V-Strom 650A (Sold)
"Remember, you don't really own anything you can't carry at a dead run."
Cambion is offline
