$10 top case - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 18 Old 11-28-2006, 02:51 AM Thread Starter
$10 top case
I found a samsonite silhouette 5 hard suitcase at a second hand store for $5. The case measures approximately 22X22X11. The key was missing, for $2 a lock smith made me a new key. It took a couple bucks worth of stainless bolts and an hour or two to modify and bolt the case to the rack. Plenty of room for a weekend, or typical grocery trip. At least until I figure out what my adventure luggage solution will be. I'll post a photo when i am able to figgure out how.
I was looking forward to testing my new penny tech trunk, being a little concerned if there would be any affect on stability at speed. I only tested the stability up to an indicated 9200 rpm in 6th gear
The bike actually seems to be less affected by crosswind now than before mounting the case, but I noted a peculiar phenomenon. When cruising at an indicated 90-95, there was a tendency to oscillate back and forth only if I let my legs totally relax to the point that they where my knees pulled out from the sides of the tank a couple of inches on either side. At this point the wind coming off the faring would buffet my legs, alternating to either side, and the bike would rock from side to side in opposition to my legs. Any one else have this occur?
et3dotcom is offline
post #2 of 18 Old 11-28-2006, 06:28 AM
Daryl,
This warrants a picture.
mikevstrom is offline
post #3 of 18 Old 11-28-2006, 07:54 AM
9200 rpm's in 6th gear on a Wee is what... 82 mph?
DucToStrom is offline
post #4 of 18 Old 11-28-2006, 08:00 AM
Heavy's Avatar
That's by the speedo...corrected its 76 mph.
DL1000K6
Heavy is offline
post #5 of 18 Old 11-28-2006, 08:32 AM
WeThereYet's Avatar
Poor little thing just screeeeaming for an O/D!
WeThereYet is offline
post #6 of 18 Old 11-28-2006, 06:07 PM
Gotta be a misprint.
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
post #7 of 18 Old 11-28-2006, 08:11 PM
You guys have no sense of humor....
post #8 of 18 Old 11-28-2006, 11:53 PM Thread Starter
another try on the photos
hope this works this time
post #9 of 18 Old 11-29-2006, 12:17 AM Thread Starter
Not a misprint -- it turns out that the bike is perfect for my needs -- the rpm limit in 6th exactly matches my wife's rpm limit in 6th -- she proclaimed "that's fast enough" right at 9200 in 6th -- good thing cause this dl650 had no more. (my bike is totally stock except for the new $10 case)
Of course this top case test rpm loss test was done in carefully controlled off-road conditions -- never attempt top gear rpm settings in excess of 5600 rpm on the freeway as this will exceed the 70mph speed limit
post #10 of 18 Old 11-29-2006, 07:27 AM
You rode your wee 9200 RPM in 6th gear OFF ROAD????
icanfixthat is offline
