Bar risers? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 10-11-2012, 05:04 PM Thread Starter
Bar risers?
Just bought a 2011 v strom 650 and want to know, Do you have to use line extensions if you want to use bar risers?
newt08 is offline
post #2 of 5 Old 10-11-2012, 08:32 PM
Some say yes, others no.
When I added the 1up/1back on my L1 Wee, I also added the extended brake line.
DL650A L1 - White
skysensor is offline
post #3 of 5 Old 10-11-2012, 08:34 PM Thread Starter
thanks for the info
newt08 is offline
post #4 of 5 Old 10-11-2012, 08:36 PM
PDaddy's Avatar
2009 with ABS and I needed to extend the brake line with 2" rox risers. Everything else was okay but tight. There was no way the brake line was going to make it. Blair from SV Racing set me up.
PDaddy is offline
post #5 of 5 Old 10-11-2012, 08:36 PM
PWD
PWD's Avatar
If you have ABS, then you will definitely need to extend the brake line. If it is a non-abs, you most likely will not need to extend it.
PWD is offline
