Lesson learned: heated grips - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 17 Old 11-18-2006, 08:25 PM Thread Starter
bobosmite's Avatar
I spent about seven hours today installing Dual Star heated grips. It was my first time stripping down a Strom, so I took my time and learned a few good things.
http://picasaweb.google.com/bobosmite/MotorcyclePics
1. Cover the battery with a (dry) towel.
2. It's tight, but you don't have to remove the Givi bars.
3. Clean the airbox while you're at it.
4. There's a "secret screw" on the side cowling...don't miss it.
5. It's easier to put it back together than it is to take apart.
The most important thing I learned: Buy PN# 36852-06G00 (horn plug wire). I spent half my time trying to tap the connector and there's just not enough room to work. I couldn't shave the wire prior to tapping and tried to hand-tighten the connections. It would have taken a whole two minutes with the OEM connector.
bobosmite is offline
post #2 of 17 Old 11-19-2006, 12:28 AM
Just spent the afternoon/evening doing the same thing - though I'm not done yet. I did not take off the tank. I just took out the fairing bolts that go into the radiator and the bolt at the bottom of the rad and swung the rad forward. I also removed the black plastic piece under the tank on the left side - though that turned out to optional.
From there I could see the heated grip connector. It was taped tightly to the wiring harness. There were two connectors at the end of the harness that needed to be unplugged.
Lying on the ground on the right side of the bike, I reached up in front of the forward cylinder and released the yellow wiring harness and the whitish/clear 3-wire one that is also in that bundle. It took me a long time to figure out how to release each harness as I couldn't see anything and I could barely move my hands in there.
With the two connectors released, I was able to pull the end of the wiring harness out and untape the heated grip connector. I had about two inches of free wire after removing the tape. I just tapped my power leads into that. I used those connectors that fold over and pierce the wire's jacket. Not sure how good they are but I can fish the harness out now in no time if I need to fix it.
At the other end I decided to put my on/off switch in where the blank spot above the starter button. I managed to find a nice high/low/off switch to fit in there. I had to make the hole bigger and also mod the switch a bit. But it looks pretty good. It took me several hour to whittle the hole just the right side. I also cut myself twice. Once with the know and once on the plastic itself.
Tomorrow I have to finish the install before lunch.
If at a later date I decide to add a heat-troller I've left enough wire on each heater that I can re-route them to the HT.
DL650K5 (Silver)
aircav is offline
post #3 of 17 Old 11-19-2006, 12:49 AM
I have this exact connector (unused, in pkg) in my garage if someone would like to buy it. I'm currently on the road but will be back to AZ in less than 10 days.
Stromette
STROMETTE is offline
post #4 of 17 Old 11-19-2006, 07:56 AM Thread Starter
bobosmite's Avatar
I should have said I was working on a DL1000. I only *wish* the radiator would swing out of the way. There's a radiator hose on the right side that allows the radiator to only move about 1". I'm only going back in there one more time...with the right part! <smile>
2014 Suzuki DL1000
SEARCH is your FRIEND
post #5 of 17 Old 11-19-2006, 02:06 PM
Sorry didn't know there was a difference in the rad setup on the V.
I've run into a problem of my own. When I put the start switch back together things did not go so well. I push the button and nothing happens. The bike goes through its boot up sequence and primes the fuel pump but it won't start. The headlight go out which at first I thought indicated a weak battery but I've determined that for the K5 the second set of contacts on the starter switch turn off the headlights during the start. That's an educated guess, can anyone deny/confirm this? I only have the schematic for a K4.
I'm pretty certain I just didn't get the second harness seated properly. Just checking now to see which harness goes to the starter motor. Glad I have a service manual.
DL650K5 (Silver)
aircav is offline
post #6 of 17 Old 11-19-2006, 02:18 PM
larolco's Avatar
Sounds like a lot of work, guys.
I had the Suzuki grips installed on my Vee in about one hour. It is a bit tight getting at the harness, but I was able to do it with a couple of pairs of long needle-nose pliers. No crimping or stripping of wires required. Just plug into the harness. I only had to remove the right side fairing to do it.
DRZ400SK17
larolco is offline
post #7 of 17 Old 11-19-2006, 03:54 PM
Found the problem... I had somehow knocked the harness off the clutch lever. You can't start it without that.
DL650K5 (Silver)
aircav is offline
post #8 of 17 Old 11-20-2006, 10:05 AM
Cheff's Avatar
I installed my Suzuki heated grips in about an hour. No special tools were needed, I did not even use needle nose pliers. Just loosened the radiator and swung it out (it does not move very far out) put some Dy electric grease on the connector and stuck my hands in there to plug it in. I did cut my hands all to hell in there but that could have been prevented with the pliers or some mechanic gloves.
By the way I love the heated grips, what a difference on my commute in the morning.
Cheff is offline
post #9 of 17 Old 11-20-2006, 10:14 AM
Heavy's Avatar
Heated grips sure can make a difference in your ride.
You should fill out more info in your profile. That way, if it says you're in Tucson where its in the 80's, we Northern guys can give you crap about it.
DL1000K6
Heavy is offline
post #10 of 17 Old 11-20-2006, 04:24 PM Thread Starter
bobosmite's Avatar
HEAVY, do you ride on the snow and ice during the winter or do you have to wait until the roads are clear? It gets close to freezing in FL, but it never snows.
2014 Suzuki DL1000
