Heated Grip Cement - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 09-04-2012, 05:53 PM Thread Starter
Borghi's Avatar
Heated Grip Cement
I just purchased the Oxford Heater Grips and the package includes something Oxford calls "superglue". Does anyone know if this can be removed without destroying the throttle tube should I decide to change grips in the future? Would I be better off trying regular grip cement? Any advise would be appreciated!
Borghi is offline
post #2 of 3 Old 09-08-2012, 11:08 AM
reitsmjo's Avatar
It will come off if you slowly cut away the grip and peel it off. Oxford sells replacement grips on a single basis should you ever need to replace one. The residue left is crusty and you can carefully scrape the loose stuff off with a knife.
2008 Ducati Hypermotard 1100S
2007 Ducati Multistrada 1100 (Wrecked)
2012 Suzuki VStrom DL1000
reitsmjo is offline
post #3 of 3 Old 09-17-2012, 10:19 AM
I just used hairspray...
The first guy on the block with a 2010 white V-Strom
Philander is offline
