Center stand, Lift or Both - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 11-14-2006, 06:58 PM Thread Starter
Funtrainsf's Avatar
DL650K6 here.... Trying to figure out the best option for me to do my regular maintenance (lube, oil changes, etc).
Would the center stand be enough, or do you suggest I use a lift?
Any reason to get both?
Funtrainsf is offline
post #2 of 8 Old 11-14-2006, 07:22 PM
Heavy's Avatar
Centre stand is good so you can lube the chain when you're away from home.
Lifts are up to you. They can make it easier to have both ends of the bike in the air at once.
DL1000K6
Heavy is offline
post #3 of 8 Old 11-14-2006, 07:24 PM
Here's how I lift mine, no heavy wrenching, just clean wheels and lube/clean chain. Re-bar and 2 by blocks.
click to enlarge
djb383 is offline
post #4 of 8 Old 11-14-2006, 07:27 PM
Heavy's Avatar
I had one of those for a cruiser I used to ride. I never felt the lift was very secure fore and aft. Crank on the rear axle nut or something and the bike will come off the lift.
DL1000K6
Heavy is offline
post #5 of 8 Old 11-14-2006, 07:30 PM
Heavy's Avatar
Forgot to mention. Check the oil level in the hydraulic cylinder. I put my bike up to the highest possible position and set the lock. Came back the next day and the cylinder wouldn't lift the bike enough to take the lock off. I had to remove the cylinder from the jack, with my bike on it, top up the hydraulic oil and re-install the cylinder in the lift. :twisted:
DL1000K6
Heavy is offline
post #6 of 8 Old 11-14-2006, 08:03 PM
That's why I said "no heavy wrenching".
djb383 is offline
post #7 of 8 Old 11-14-2006, 08:21 PM
Wee_Willie's Avatar
Centerstand works just fine! It's hard to take a lift on the road with Ya! If you have a flat/puncture or need to do a chain adjustment far from home... Centerstand!
[url]http://www.flickr.com/photos/[email protected]/[/url]
IBA#27466
2007 Suzuki GSF1250K7 Bandit - Black of course!
2006 Suzuki DL650K6 - Alaska and back July/Aug 2007
1978 Yamaha SR500E - Frame up restoration in progress
1968 Yamaha DT1 Shorttracker / "Bargain" Craigslist find... yeah, right
Wee_Willie is offline
post #8 of 8 Old 11-14-2006, 08:43 PM
Djb383, remember, that was " HEAVY " wrenching. lol.
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
