Fuse(s) questions - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 07-07-2012, 11:18 AM Thread Starter
js29's Avatar
Fuse(s) questions
OK, I purchased and rec'd my Eastern Beaver V_Strom specific switched 3 circuit accessory kit. I have installed the kit and connected the switched power source and all works well.
My situation is this. I bought this kit to power my Garmin Nuvi 550 that I purchased and routed the Garmin Power/Data USB cable (Garmin Serial Power and Data Cable for Nuvi 5xx Series and Zumo 220) and I am ready to connect the leads to a circuit on the Eastern Beaver kit.
The Garmin cable has a glass fuse on the hot wire that as best I can tell reads .750mA/250VP on one end, and 312 on the other end.
Given that inline fuse, what amp fuse should should I use on the Eastern Beaver circuit, 2, 5, 10, or 15?
Another question, since I have a fuse on the Eastern Beaver circuit do I need this inline circuit?
Thanks for some guidance for an electrical/electronics novice.
No, more like chewed out. I've been chewed out before ...
[URL="https://www.stromtrooper.com/members/28023-js29-albums-my-v-strom-picture12417-img-1720.jpg"]2013 BMW R1200RT[/URL] Black
[URL="http://www.silenzzzz.net/bike/ral_bike.jpg"]2007 Raleigh Mojave 8.0[/URL] (powered by me)
[B]Past Bikes[/B]
1973 Honda 350
[URL="https://www.stromtrooper.com/picture.php?albumid=250&pictureid=2525"]1982 Kawasaki 440 LTD[/URL]
[URL="https://www.stromtrooper.com/picture.php?albumid=250&pictureid=2498"]1997 Honda XR250R[/URL]
[URL="https://www.stromtrooper.com/picture.php?albumid=250&pictureid=2498"]2004 Honda CRF50F[/URL]
[URL="https://www.stromtrooper.com/picture.php?albumid=250&pictureid=1136"]2009 Suzuki V-Strom 650[/URL] [COLOR="Gray"]Silver[/COLOR]
[URL="https://www.stromtrooper.com/members/js29-albums-my-v-strom-picture2748-2002-yamaha-tt-r125l.jpg"]2002 Yamaha TT-R125L[/URL] (Son's)
Added Gear/Mods: FirstGear Silverstone Mini Tank & Tail Bags, Bungee Cargo Net, D260ST Givi Windscreen, Madstad Bracket, Superbrace, Grip Puppies, Suzuki Gel Seat, Aprilia Tuono Mirrors, RideItMoto Adjustable Levers, Murph's Kits Center Stand, Garmin Nuvi 550, Rick's GPS Mount, Ram Mounting Accessories, Eastern Beaver 3 Circuit Solution, Garmin Power/Data Cable, Michelin Pilot 3 tires, Speed Bleeders, Burns USB Outlet, Cramp Buster.
js29 is offline
post #2 of 6 Old 07-07-2012, 11:47 AM
A 2A is all you need. With that, you don't need the Garmin fuse and can cut it off. You do need the box in the line closer to the connector end. It reduces the 12V bike connection to 5V to run the GPS.
post #3 of 6 Old 07-07-2012, 11:51 AM Thread Starter
js29's Avatar
Thank you, that is what I thought, but I just wanted to make sure.
Would you think I should maybe try and find a 1amp fuse rather than the 2amp one just to be closer to .750? If so, where might I find one, because I have looked all over and can't locate one.
THANKS!
[B]Past Bikes[/B]
1973 Honda 350
js29 is offline
post #4 of 6 Old 07-07-2012, 12:21 PM
Don't worry about it. The fuse is to protect the wire. An overload, even in a small wire, will blow a 2A fuse well before the wire gets hot enough to damage anything else.
post #5 of 6 Old 07-07-2012, 12:39 PM Thread Starter
js29's Avatar
Thanks. That is why I identified myself as and electrical/electronics novice.
[B]Past Bikes[/B]
1973 Honda 350
js29 is offline
post #6 of 6 Old 07-08-2012, 03:17 PM
I have a 1 amp in mine. No problem getting it at an Auto store.
'09 Wee Strom
'08 Triumph Tiger 1050
Matts-Strom is offline
