Another source for lowering links? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 07-16-2004, 07:35 PM
Eeyore
I contacted Seth Laforge regarding lowering links for my wife's DL650 and was told that he did not have any in stock and wasn't sure when he would be making some more.
Anyone know of an alternate source, other than having a local machine shop fabricate some?
We are wanting to lower the bike 7/8" or 1" .
Thanks!
post #2 of 4 Old 07-17-2004, 02:47 AM
I got a pair off ebay from Goldistar(I think that was his/her name) for $25+shipping, these were the ones made for a Hayabusa but they fit the 650. I believe that using the last hole on the links is about 6mm longer than stock, so it lowers the bike by an inch or a bit less. The grade of aluminum is slightly lower than others but they seem strong enuf. Seems to be an excellent price and good quality (the holes on mine needed to be reamed out just a bit, it looked like the holes were punched out, not drilled.) Just search for lowering links on ebay and compare, good luck.
Silver 04 DL650K4 V-strom
GetFuzzy is offline
post #3 of 4 Old 07-27-2004, 01:55 PM
thmprdude
might also try murphskits.com
post #4 of 4 Old 07-27-2004, 07:06 PM
kawidan
search for a company called kouba.they make links for all the off-road and dualsport models.they may have something for you.i've used them before and they are well made with hardened bushings.
Raising and Lowering Links richlandrick AdventureTech LLC 66 03-03-2019 11:36 AM
Chain Slack with Raising Lowering Links richlandrick General V-Strom Discussion 0 08-14-2015 10:19 AM
Murph's Lowering Links Installation & Review Green427 Maintenance, Tech and Products. 1 11-20-2013 04:09 PM
