Another home made luggage rack - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 06-01-2012, 11:55 AM Thread Starter
I copied another member here and made a rack to fit on top of my Pelican case. I have to add that my brother did the welding and I did the cutting and bending. Here are some Pics.
I coated it with truck bed liner so that I can repair it if it gets scratched.
Here it is on its new home. I have silicone sealer under the bolt heads and on the washers inside the case so it does not leak. I torqued the bolts to 12 ft lbs as to not crush the case material.
Tacoma29 is offline
post #2 of 3 Old 06-01-2012, 11:59 AM
Most excellent!!!!! Now get you some small ROK Straps and you're in biz-nis........!!!!!!!
www.easternvstromrally.com
mark444 is offline
post #3 of 3 Old 06-01-2012, 12:23 PM
What Kinda Bike Is That?
Black Lab's Avatar
I would have sent you mine. I don't use it anymore!
B.L.
Black Lab is offline
