How to I reduce idle speed from 1200 to 7-800 ? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 16 Old 10-28-2006, 06:17 PM Thread Starter
Ok this is probably an easy one but how do I reduce idle speed. After opening the pipes up it is idling to fast and doesnt sound right.
Heavy, any ideas?
*I call my bike the A10, Wartie(compares to the "DOES IT ALL", military airplane called the A10 Wart Hog)
Bikes, yup got some;
xr650
Road King
WR360 Husky
It490
996 Vstrom
450exc KTM, Orange
and some wee ones for the grand kids.
Dirty Dog is offline
post #2 of 16 Old 10-28-2006, 07:05 PM
Which bike, 650 or 1000? What year? In any case, your target is too low. Check your manual for the proper idle speed. These are twins, not V-8s. The proper idle speed will have 4 digits.
post #3 of 16 Old 10-28-2006, 08:46 PM
Idle adjustment speed screw, located under the frame on left side of bike. By the way.......you were at the correct idle speed. :wink: You should be between 1100 and 1300 rpm, pretty much for either Strom model. This aint no Harley twin that idles at 600 rpm.
post #4 of 16 Old 10-28-2006, 10:34 PM Thread Starter
Grey Wolf, 2005 and it's 996 or 1000 as the brochures like to call it.
Big B the guy with the same year as mine and the color I wanted when I bought the bike but had to settle for dark blue. Black will be the new color of this bike right after the first of the year. I'm gonna change the Vstrom insignia color from silver to KTM orange, I think it will look Sooooo cool.
The deal is I did the 4 holes in the end of each pipe and now with the extra noise, it sounds like its idling to fast. Anybody have the reasoning behind the elevated low idle up at 1200? Brian, where is the idle screw..more detail if ya got it.
Thanks
D-dog
xr650
Road King
WR360 Husky
It490
996 Vstrom
450exc KTM, Orange
post #5 of 16 Old 10-28-2006, 10:53 PM
Thanks
D-dog
Yes...BLACK is awesome!!!!! The reason that your rpm's changed, is due to the decrease in back pressure from the hole mod. Your bike is breathing a bit better! :wink: When I take my baffles in and out of my Leo Vince cans, I always have to re-adjust my idle speed.
Go to the left side of your bike and bend down. If you look below the frame rail under your tank, you will see a phillips head screw that is mounted onto a stiff tube. That is your idle speed adjustment...be sure you are fully warmed up before tweaking it. Look in your owners manual, it has a very good pic and description of it.
Fill out your profile a bit more, so we all know where you are from and what ya ride!!! 8)
post #6 of 16 Old 10-29-2006, 02:55 AM
The idle screw location is in the owner's manual.
The Strom's idle speed is a maintenance spec, like tire pressures or engine timing It varies from engine to engine. Smaller engines generally have higher idle speeds because that's where they run the best - if the idle is too low, they won't run smoothly and may stall. Furthermore, a too-low idle tends to aggravate the off-idle abruptness that many FI bikes tend to have that makes it more difficult to get a smooth power application at corner exit.
All-in-all, I think you'll find it a poor tradeoff to make the idle lower than spec in an attempt to quiet the bike down with your opened up pipes.
- Mark
markjenn is offline
post #7 of 16 Old 10-29-2006, 07:23 AM
Heavy's Avatar
Re: How to I reduce idle speed from 1200 to 7-800 ?
Heavy, any ideas?
Idea? Yup, don't do it.
Set the idle speed that low and you'll be back asking why your bike runs so poorly.
Keep an eye on your other thread, Mortaine may come back and explain why. Of course, he is so advanced, our feeble, little minds won't be able to comprehend, but at least it will be out there for us. :roll:
DL1000K6
Heavy is offline
post #8 of 16 Old 10-29-2006, 05:32 PM
Harley's
Even Harley's shouldn't idle that low. The oil pump doesn't pump enough volume to protect engine.
Are we gonna ride or dick around all day?
sporthog93 is offline
post #9 of 16 Old 10-29-2006, 05:32 PM
Harley's
post #10 of 16 Old 10-30-2006, 04:41 PM
Idling a DL1000 below 1,000RPM will cause "stalling" (at least in hot weather) when coming to a stop. Experience taught me that.
Grandpa is offline
