Power outlet help needed - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 3 Old 04-15-2012, 03:59 PM Thread Starter
nobie381's Avatar
I am not an expert in wiring but I understand how a circuit works etc. I was able to install the Stebal air horn with out problems.
With that being said I am looking to purchase Rick Hughes auxiliary shelf and in ordering it I need to know what outlet's I want to use so he can pre-drill the holes. I know at least one will be a 'Cigarette' Socket so I can connect my phone to charge and I am debating to do a BMW socket because I will probably get some heated gear this fall.
With that said can anyone tell me where they have purchased their outlets. I was thinking Eastern Beaver's VStrom Front Socket Kit X2. This way my amateur wiring would not be an issue. Just "plug and play", no cutting and no worries. Suzuki VStrom Electrics
My issue for this option is I don't know the size for these outlets for the Rick Hughes plate and if this is the best option.
Side note, with the air horn and these two outlets will I have power issues?
2011 SUZUKI DL650 V-Strom ABS/Pearl Mirage White
Farkles: Aprilia Tuono mirrors / Pat Walsh Design Super Brace / DL1000 Seat / Givi engine guards / RR Peg Lowering Kit / Madstad Bkt w/ OEM or Givi Shield / PL532 & E41nn / SW-Motech CenterStand / EB PC-8 - 2x power outlets - Datel Voltmeter - Stebel Horn with PWD setup - Digital Slim H4-3(9003) Bi-Xenon HID - 1157 LED Brake lights
Shiro Nakama Hachi [SIGPIC][/SIGPIC]
nobie381 is offline
post #2 of 3 Old 04-15-2012, 08:21 PM
I would go with Eastern Beaver
According to- Extras
Powerlet hole needs to be 11/16" and a regular cigarette outlet hole needs to be 1 1/4"
DL1000K7
jayDL is offline
post #3 of 3 Old 04-16-2012, 10:24 AM
henerythe8th's Avatar
If you're not running anything off the outlets, nor Stebel-blasting anyone, you'll never have electrical capacity issues...
...unless, of course...
...your charging system is malfunctioning or you have some high load electronics using your available power elsewhere.
If you are doing all of that other work, you should install a voltmeter in that panel, too.
That way, you will know when you are approaching your electrical limits.
2011 MG Stelvio
henerythe8th is offline
