Don't glue that OEM Suzuki LH heated grip in place just yet - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 5 Old 09-30-2006, 07:32 PM Thread Starter
snowcommuter's Avatar
The heated grips are only heated by a 1" wide element the length of the grip. On my 07 650 the instructions show that the LH grip's wire needs to point straight down. The problem is that the hot part ends up just on my finger tips and without a firm squeeze the grip feels like it doesn't work at all. By rotating it as shown in the photos the heat is right under my palm and works quite well. I was a bit bummed that the entire grip isn't heated (especially for big $$$) but when positioned they function ok.
http://Snowcommuter.smugmug.com/gall...449/1/98992548
05' ST1300
07' V-Strom 650
snowcommuter is offline
post #2 of 5 Old 10-07-2006, 10:57 PM
USMC V-STROMMER's Avatar
I have been toying with the idea of heated grips. I noticed that you took extra care to show how the wiring leading to the throttle side grip goes over the kill switch. Is this typical of all installs of the Suzuki heated grips or is there a way to avoid it?
Shiny side up, Rubber side down!
DL650K5/Red
Semper Fi!
USMC V-STROMMER is offline
post #3 of 5 Old 10-08-2006, 12:06 AM
USMC, my installation instructions indicated the right grip wire should lead forward so it doesn't interfer with the kill switch. Mine doesn't cross or interfer with the kill switch in any way. Sorry no pictures.
tac3 is offline
post #4 of 5 Old 10-08-2006, 08:02 AM
tmcgee's Avatar
>> I have been toying with the idea of heated grips. <<
I use them all year, but when it's really cold, the Gerbing gloves are better.
tmcgee is offline
post #5 of 5 Old 10-11-2006, 03:56 PM
Just did a search on that gear. Looks like a good product. Did you purchase a heat troller to go with the gloves or have you found them comfortable enough just to go with the on/off option?
Steve
DL650K5/Red
Semper Fi!
