Your turn signals suck! - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 44 Old 09-24-2006, 10:15 PM Thread Starter
I've really gotten tired of hearing that from my riding buddies and decided to try to fix it. After a little stare time it hit me. The turn signal buckets are black plastic which just soaks up any & all light from the bulb. Ideally the bucket should reflect light like a polished headlight bucket does or the chrome turn signals on cruisers and the like. So I pulled the lens and bulb, put in a sacrifical bulb, masked off the outside of the signal and surrounding parts and spray painted the whole inside of the turn signal with shiny aluminum paint. After the paint dried I re-assembled it and flipped on the 4-way flashers. The difference in visibility between the painted signal and the black signal was amazing! Both rears are done now and I'll fix the front signals later this week.
Ideally, Suzuki should put a little refective disc behind the bulbs on these signals, but in the meantime a shot of spray paint does the trick.
DL650K6 - Red
zero_it is offline
post #2 of 44 Old 09-24-2006, 10:33 PM
Send a message via MSN to drewgg
I've seen another fix whare you fit mini spot lamps in place of the stock bulbs. I think that's the way I'll go when I get chance to have a look at them. :wink:
Drew G.
KLV Fundamentalist.
drewgg is offline
post #3 of 44 Old 09-25-2006, 12:34 AM
zero_it
Thanks for the info. Something I've never worried about - now I have an excuse for the pills! :shock:
drewgg
Keep us informed. Sounds like an interesting mod.
Maybe you can do something with a paraffin torch and a bar of solder?
Al
"If our world didn't suck - we'd all fall off!"
Anon
kamloopsal is offline
post #4 of 44 Old 09-25-2006, 02:35 AM
Zero_it................like your idea but I am wondering. How well will the paint stick to that plastic housing? Some plastics just defy all attempts to do anything with them. Keep us updated by checking ocassionally to see if the paint stays in place. Suzuki really should have known better to begin with.
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
post #5 of 44 Old 09-25-2006, 08:10 AM
JetJaguar's Avatar
A lot of people stick a piece of aluminum foil behind the bulbs to act as a reflector.
- Jet Jaguar
It's not an adventure unless you need a tent, a passport, and a leather glove for your shooting hand.
'05 DL650
JetJaguar is offline
post #6 of 44 Old 09-25-2006, 11:18 AM
csr67's Avatar
An even easier fix is to buy a roll of reflective foil tape. About $4 at your local homer depot or Blowes. One roll will do about 100 v-stroms. Remove the lens, pop-out the bulb and stick the tape to the inside of the black plastic housing. Takes all of 10 minutes for the whole bike an improves the signal brightness about 300%.
csr67 is offline
post #7 of 44 Old 09-25-2006, 02:36 PM
MATTMAN's Avatar
That's what I did. I actually glued foil to cups cut from an egg carton and put them in. Works pretty good.
650...Anything more than a handfull is wasted
MATTMAN is offline
post #8 of 44 Old 09-25-2006, 04:02 PM
Kawidad's Avatar
I did the foil trick and it works just fine and it was totally free (basically). :wink:
Kawidad
2007 DL1000K7
Kawidad is offline
post #9 of 44 Old 09-25-2006, 06:33 PM
RockyMtnRoadRash's Avatar
I'm tinfoiling mine after work. I mean.. uh.. .not screwing off at work, no sir, not me.
-RMRR
'05 DL1000 - Dead at 66K miles.
Nerding it up at Wheelnerds.com
RockyMtnRoadRash is offline
post #10 of 44 Old 09-25-2006, 10:27 PM
zed88's Avatar
Send a message via AIM to zed88
Make turn signals for your mirrors :P and of course stick shiny stuff in the housings
Click for movie.
zed88 is offline
