Hot Grips installed - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 4 Old 09-23-2006, 03:17 PM Thread Starter
Hot Grips installed
Hot Grips working well powered from the plug mentioned by a few other Strom owners (thanks again). It took quite a bit of excavating to get to the plug after that airbox was removed but I suppose it was inevitable that I'd be digging around in there anyway.
Attached is photo of the switch location. I wanted it somewhat out of the weather and not liable to collect moisture. The rubber cap is easily found in a good hardware section.
2006 DL 650 in red
Motech center stand
Funky radiator guard
Givi windscreen
Givi topbox
Hot Grips
MadStad brackets
Stebel Horn
Sailor is offline
post #2 of 4 Old 09-25-2006, 09:59 AM
allonsye's Avatar
i once saw that someone on this board outfitted his strom w/marine quality switches. that's what i'll do when the time comes. i think it would be reasonable to assume that they'd be waterproof at the very least.
suspend reality as often as possible
allonsye is offline
post #3 of 4 Old 09-25-2006, 11:44 AM Thread Starter
The wires that I used are marine grade to help resist corrosion and I'm still looking for a marine-grade rocker switch. The one supplied feels kinda flimsy.
2006 DL 650 in red
Motech center stand
Givi windscreen
Givi topbox
Hot Grips
MadStad brackets
Stebel Horn
Sailor is offline
post #4 of 4 Old 09-27-2006, 12:55 AM
BumbleBee's Avatar
I believe Cole-hearsee makes some marine grade switches, I've used a toggle switch that has been dipped in plastic with a rubber boot over the toggle. they seem to be fairly weather tight.
03' yellow dl1000 Rich's seat, custom built racks with ortieb drybags
givi crash bars, powercommander,mm spacers,SV slipper clutch
43t sprocket, speedohealer custom 04'+MpDesigns/madstad windscreen
BumbleBee is offline
