$10 heated grips? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 6 Old 09-16-2006, 11:36 PM Thread Starter
$10 heated grips?
So I shouldn't be left to wander stores alone...
Back in the automotive section at wal mart they had these electrically heated coffee mugs for sale $3. Well, that's interesting, and at that price worth the risk to buy and gut them. I knew there had to be some sort of resistor wire or something in there to heat it up. So I bought two of them.
Here's what I got.
First of all I took apart the cig adapter to make sure there wasn't any weird power supply going on in there. Nothing more than an LED and resistor to show it's powered up. So it's getting the full 12vdc.
Tried to pry the plastic liner out. But resorted to just breaking it off. a pair of pliers made quick work out of them.
I cut the leads off in the cup. Dunno what to do with the stainless steel now.. Guess I'll use it in the shop to hold bolts or something.
The wire is held in place on the liner with tape. Just pulled it off and the wire comes right off.
Here's the resistor wire. There's a temp switch on the base. I'm not going to use it.
A pic of all the bits.
I'm going to take my grips off. I just put the cushy foam ones on. I'm going to put some of the alum tape on the tubes to reflect the heat. Then wrap the wire on the tubes. Then cover with tape like they had. I'll leave an extra loop of wire coming off the throttle tube to help. Then reinstall the grips. To control it. I'm going to put a three way switch. One will be a full 12V, the other will hit a resistor block, then the heater wire. That'll give me a high and low. I'll even use the two LEDs to show me that the system is "on". Heated grips for $10...
patracy is offline
post #2 of 6 Old 09-17-2006, 12:40 AM
If you have contact between uninsulated wire and aluminum tape, bad things will happen. Make sure bare wire cannot contact anything conductive,
post #3 of 6 Old 09-17-2006, 09:07 AM Thread Starter
The wire isn't bare. There's a knitted fabric that covers it. I'm going to put the alum tape, then a round of clear, then wire, then another clear over it. Then the grips.
Also here's a better way to use the wire itself to regulate temp. No waste from an added resistor.
patracy is offline
post #4 of 6 Old 09-17-2006, 10:45 AM
This really belongs in the best custom farkle contest and should be the clear winner. Thanks for the great write-up.
DLK4
iron butt strommer, daily rider and diehard airhead
mikevstrom is offline
post #5 of 6 Old 09-17-2006, 11:47 AM
Ah! The good old DPDT switch to change between serial and parallel trick. Good thinking. It will be interesting to see if the heat generated is in a useful range with one wire per grip. You might also try wiring on top of the stock grips and adding grip puppies on top of that.
post #6 of 6 Old 09-17-2006, 06:37 PM
That sounds a little easier GreyWolf. Good thinking.
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
