Anyone done Givi Sideracks with Pelican Cases? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 12 Old 09-15-2006, 09:23 PM Thread Starter
NoVA-Strom's Avatar
I have seen the SW-Motech with the Pelicans, but has anyone done the Givi PL532 racks with Pelican side cases? If so can you post some pictures?
R.I.P.
Red 2006 V-Strom 650: "the most shockingly competent machine in the world today"
Alpenkönig (a.k.a. King of the Alps): 2005, 2006
1989 Sportster Bobber Hardtail
1990 Electra Glide with Cop Bags
NoVA-Strom is offline
post #2 of 12 Old 09-17-2006, 07:40 PM
Been there, done that.
Actually really pleased with the outcome.
I don't have picture capability, but basically - centred the racks on the cases on the floor, drilled holes (racks have threaded holes), mounted racks to bike, bolted cases to rack (using large washers on inside of case)
Just that simple :-)
Not quickly removable but so far haven't really found that to be an issue.
The cases have holes for padlocks, just bought a set keyed alike.
Very sturdy and best of all, very (relatively) cheap!
mayday is offline
post #3 of 12 Old 09-17-2006, 08:20 PM
GeoBiker's Avatar
Just curious, which model Pelican cases, and do you know the overall width?
[B]Blue, K5-DL650[/B]
GeoBiker is offline
post #4 of 12 Old 09-18-2006, 12:46 AM
Overall width is 38" - not any wider than the bars - the main reason I went that route as it still allows splitting/filtering.
Used the 1550's - won't fit a full face, but plenty big enough for average commuting, groceries, med. length trips etc
mayday is offline
post #5 of 12 Old 09-18-2006, 08:57 AM Thread Starter
NoVA-Strom's Avatar
No issues working with the rear wheel for chain maintenance, etc.? I was thinking about the 1430's, my only concern is that they only hold about 15L each. Looks like the 1550 holds 32 each. The new 1440 seems like it is too big and too heavy.
R.I.P.
post #6 of 12 Old 09-18-2006, 10:48 AM
No issues at all, the racks are actually at a slight angle, so the widest point is at the bottom. Still easy to lube/clean chain etc.
Again, for me, size of the 1550 is perfect and weight is really not even close to being an issue.
mayday is offline
post #7 of 12 Old 09-18-2006, 10:50 AM
GeoBiker's Avatar
I've been considering the 1520s as an alternate. They hold about 25L which is more than my Tourmaster soft bags. Maybe enough for short hauls, longer hauls if combined w/ trunk and a duffle. About an inch or more (total) narrower than the 1550's.
Has anyone used the 1520's for touring? Big enough, or too small?
GeoBiker is offline
post #8 of 12 Old 09-18-2006, 12:03 PM
RockyMtnRoadRash's Avatar
The Caribou setup is well worth a look. By the time you buy the givi racks and cases you're probably going to end up in the same neighborhood for price.
I can't say enough good about the Caribou rack and cases. Super solid, wonderfully unobtrusive when the cases are off, and just overall great design. Incidentally, one thing you should steal from Caribou if you DIY is the cables that catch the lid. They only let it open to about 80 degrees, rather than all the way to 90. This is awesome because it keeps everything from falling out on the low side since it acts as a catching point, not a getaway ramp.
-RMRR
'05 DL1000 - Dead at 66K miles.
Nerding it up at Wheelnerds.com
RockyMtnRoadRash is offline
post #9 of 12 Old 09-18-2006, 02:18 PM
GeoBiker's Avatar
No doubt the Caribou are nice! I particularly like the solid racks. But:
2 - 1550's @ $85ea. = $170
1 - GIVI Rack = $145
Assortment of hardware, maybe = $20.00
Satisfaction of a rainy day DIY project = Priceless! (sorry, couldn't resist)
Total: ~ $330. Or less than half the Caribou.
GeoBiker is offline
post #10 of 12 Old 09-18-2006, 03:36 PM
Colin's Avatar
Instead of the 1550's , perhaps take a look at the new Pelican 1430 or 1440 toploaders. They are 25 L and 33.6 L cases and will more easily keep stuff from falling out when you open the case.
Those links are to Pelican in Canada but I would assume they are available elsewhere.
Colin is offline
