I may need the dealer for mods. Grrrr - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 20 Old 09-14-2006, 10:27 AM Thread Starter
Storm Girl's Avatar
Send a message via MSN to Storm Girl
:!: :evil: :!:
I can't get the bolt to turn to put on the lowering links!
I can't get the bolt to turn to replace the brake lever that had gotten the tip broken off!
I can't understand how the givi hard case brake lights wire in!
I can't understand how to get the oilier on (and the chain is looking dry)!
This is pissing me off! RRrrrrrrrr
This should be simple stuff
(- the oilier) but all I have managed to do
is slightly strip nuts.
:cry:
Storm Girl is offline
post #2 of 20 Old 09-14-2006, 10:51 AM
If you're using the tool kit, that could be a reason for having troubles with the bolts. A small investment in some decent wrenches and sockets would help if you haven't already done so.
Also remember that some fasteners use Lock-tite, a compound that can make it more difficult to loosen them.
Blue DL650K5
lajaro is offline
post #3 of 20 Old 09-14-2006, 11:31 AM
When I disassembled the rear suspension I found that the bolts were very tight. Bolt stretching, thread galling tight. :evil:
The Japanese are also masters at tightening philips head screws. Thankfully Allen heads are now common.
Let's go!
05 DL1000
Mountaintime05 is offline
post #4 of 20 Old 09-14-2006, 01:16 PM
The nuts are placed with the high strength threadlocker. A little heat will help break it down. The bearings should be regreased and high strength threadlocker applied before assembly. The nuts should be tightened to 56.5 lb-ft.
post #5 of 20 Old 09-15-2006, 09:02 AM Thread Starter
Storm Girl's Avatar
I am going to get some more tools.
How do I heat the nuts?
It's not like I have a place were I can use a torch.
???Lighter LOL???
post #6 of 20 Old 09-15-2006, 09:29 AM
BlackCatRacing
Home Depot/Lowes/Local Hardware
The easiest for a bike are the miniture butane tourches that all of the Box hardware stores sell.
They are a bit bigger than a Bic lighte, but can be refilled with a Can of Butane.
Next up on the list is the Butane Tourch that are about the size of a quart thermos bottle. They use replacable butane tanks that can also be purchased at the Big Boxes.
Sears Craftsman also handle both sytles of heat sources.
Ride Em
:P
post #7 of 20 Old 09-15-2006, 10:19 AM
Yes you do. I'll give you one more free mechanic session for your belated birthday present. I already have a torch.
post #8 of 20 Old 09-15-2006, 11:33 AM
Heavy's Avatar
???Lighter LOL???
You can actually use on of those high-temp, hot air guns. The kind for stipping paint and such. I have one with a snap-on concentrator nozzle. It'll get stuff hot enough to make the thread lock crackle and sizzle.
DL1000K6
Heavy is offline
post #9 of 20 Old 09-15-2006, 02:26 PM
Are you turning your wrench counter-clockwise?
the borg is offline
post #10 of 20 Old 09-15-2006, 02:51 PM
It happens - I had my drill on reverse a few times during my emulator install.
Blue DL650K5
lajaro is offline
