What is a Throttlemeister - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 8 Old 09-08-2006, 04:29 PM Thread Starter
Storm Girl's Avatar
Send a message via MSN to Storm Girl
What is it and what dose it do?
And is it worth what it dose?
Storm Girl is offline
post #2 of 8 Old 09-08-2006, 04:54 PM
Compared To What?'s Avatar
It's a throttle lock (Like a simple cruise control). . . . I've had mine on my 6Fiddy for two years. Don't use it much but when I do it does as advertised.
Compared To What? is offline
post #3 of 8 Old 09-08-2006, 05:21 PM Thread Starter
Storm Girl's Avatar
ahhhhh
cool
Thank you.
post #4 of 8 Old 09-08-2006, 06:33 PM
JetJaguar's Avatar
I have one on my bike as well. The term "throttle lock" is a bit of a misnomer. It only applies just enough pressure to the throttle tube to counteract the return spring, you can still freely work the throttle while it's engaged. It's nice to have if you're going to be on the expressway, but I find I don't really use it that much. If I had to start over with a stock bike and re-buy all my accessories, it would be near the bottom of the list. If I did a lot of interstate riding then my opinion would be different though.
- Jet Jaguar
It's not an adventure unless you need a tent, a passport, and a leather glove for your shooting hand.
'05 DL650
JetJaguar is offline
post #5 of 8 Old 09-08-2006, 10:50 PM
I use a throttle rocker and find a big difference in wrist fatigue whether the slab or twisties.
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
post #6 of 8 Old 09-08-2006, 11:27 PM
I have had Throttlemeisters on several bikes. Although they are beautifully made and definitely a high quality product, I feel their design is not very easy to use. As I recall, in order to "activate", you have to turn the end knob the opposite direction you turn the throttle to increase speed. You almost need to bring your left hand over to hold the throttle while your right hand turns the throttlemeister. I also have had universal throttle locks on bikes (have one currently on my Wee and Mean Streak). It's considerably less expensive and much easier, safer, and quicker to use. Not as pretty, but more functional IMHO. Because the universal throttle lock is so much easier to use, I use it a great deal.
MiloFu is offline
post #7 of 8 Old 09-12-2006, 02:23 PM
klong's Avatar
[quote="MiloFu"]I have had Throttlemeisters on several bikes. Although they are beautifully made and definitely a high quality product, I feel their design is not very easy to use. As I recall, in order to "activate", you have to turn the end knob the opposite direction you turn the throttle to increase speed. You almost need to bring your left hand over to hold the throttle while your right hand turns the throttlemeister.quote]
Not quite; to engage the Throttlemeister rotate it in the same as applying throttle, and to disengage you simply roll it up, same as shutting the throttle. Proper adjustment is paramount; when I last installed one I used a dime as a spacer, and I only have to use the side of my right hand to engage; they should be adjusted just snug enough to hold the throttle, but not so tight it prevents movement altogether.
Crossing your left hand over to hold the throttle is simply unsafe, and certainly not recommended.
I got mine from RL cycles - they got me the heavy model in matte black for a good discount: http://rlmotorcycles.com/home/default.htm
KevinL
klong is offline
post #8 of 8 Old 09-12-2006, 03:05 PM
Pierre Fortin
Kaoko Throttle Lock
Hey there.
Kaoko makes throttle locks for different bikes including the V-Stroms, 650 and 1000.
The quality is second to none and it installs in minutes on the Stroms.
I use mine quite a bit on the highway, sometime I still keep my hand on the grip but I do not have to fight the return spring and can relax my hand.
I don't feel its dangerous at all as the normal panic stop reflex includes closing the gas while reaching for the brake. The roling action is smooth and easy in the "Gas Off" motion.
Adventurer's Workshop sell the locks and many other items for the Stroms.
Check it out>
http://www.adventurersworkshop.com
