SW-Motech Centerstand Stability - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 13 Old 09-03-2006, 07:48 AM Thread Starter
rotorhead's Avatar
Just searched the achives on this subject but didn't really find anything, hence the new thread.
Just installed a SW Motech centerstand yesterday, no challenges getting it all bolted up, the fit is great and the bike virtually leaps onto the stand as it is so easy to use. However, as soon as I first put it up onto the stand in my garage, I was concerned with how "wobbly" overall the bike seemed. There just seems to be a lot of flex between the stand and the bike.
As a point of reference, I'm used to BMW centerstands which are as solid when deployed as the Rock of Gibraltar. I'm not concerned that the Strom will fall off the SW Motech unit, but it just does not have as solid a feel as what I'm used to. I actually took the bike down off the stand and checked the four mount bolts again for tightness, as something just seemed to be loose but they were all torqued up properly. Is this normal for those with the SW Motech unit, or should I truly be concerned that something funky is going on here?
Doesn't appear that I'll have any cornering clearance issues with the stand - I already routinely scrape the peg feelers in corners and am hoping that the stand doesn't detract from that at all.
Thanks
There's no such thing as a bad ride, some are just better than others...
rotorhead is offline
post #2 of 13 Old 09-03-2006, 07:53 AM
Reverendbiker's Avatar
I've never owned a BMW so I have no basis for comparison, but I've had the SW-Motech stand on two VStroms and both were solid as could be. Matter of fact I mount and dismount the bike by standing up on the footpegs and there's no wobble at all.
jack <><
'07 DL650, "which may just be the most shockingly competent machine in the world today"--Cycle World
www.reverendbiker.com
Reverendbiker is offline
post #3 of 13 Old 09-03-2006, 08:57 PM
Martin's Avatar
Mine is solid as well. When I rock forward to get underway it doesn't feel the least bit unstable.
Please pardon the silly question, but you didn't forget to put in the spacers did you? :shock:
- Martin
2019 650X
Martin is offline
post #4 of 13 Old 09-04-2006, 08:24 AM Thread Starter
rotorhead's Avatar
- Martin
Almost! It took me a few minutes of figuring out the diagram to decide that the spacers were to go between the SW brackets and the bike's mount point.
After wrenching on the bike yesterday while it was on the centerstand, I have to say that it really is stable enough, just still not as solid as BMWs. On the Strom, if I take hold of one of the passenger grab handles and gentle move it the handlebars will move back and forth and the whole bike wiggles a bit. Maybe I overreacted with my original post when I first saw that, because it's different than what I was used to. I know the installation is correct, so I'll just go back to enjoying the Strom now!
post #5 of 13 Old 09-07-2006, 05:58 PM
My brother has a BMW R1150R. When on its center stand the bike leaned toward the rear. The Strom I noticed leans forward due to its lengthyness. I have found that it is easier to raise than the R1150's. Probably because it is only lifting more of the rear end.
I just put mine on last week. I had doubts going into it that it wouldn't be very stable laterally but I feel ok with it after putting it on. My garage is very flat, so there was no great test. I feel like a good enough push is required to get it off the stand. I think someone should come up with a lock for them to immobilize them from coming down upon an accidental bump, etc. I would be afraid to leave any bike unattended around kids(probably because my two boys, 5 and ~3, are so crazy).
Do use a torque wrench since the info was given to tighten as well as retighten after 20-30 miles.
-Brian
80 Honda CM400E
95 GSXR750W
06 DL1000
09 DRZ400S
BrianSSSSS is offline
post #6 of 13 Old 09-07-2006, 07:36 PM
jackpiner57's Avatar
I guess mine is somewhat stable ON A FLAT SURFACE.
The only thing I use mine for is chain maintenance and rear wheel removal.
It doesn't drag in corners because it's narrow. Narrow is not as stable.
"Build a man a fire and he'll be warm for the night. Set a man on fire and he'll be warm for the rest of his life." - Confuseus
jackpiner57 is offline
post #7 of 13 Old 09-07-2006, 11:20 PM
BrianS..........Have a lowered Wee. It is a chore to get up on the center stand with loaded bags, but on the plus side I can rock it front or rear to check the tires for damage after a ride.
05 / 650 in blue
88 / KDX 200 in green
81/82 DT 175 Yamahussies
78/ GT 750 water pumper
75/Suzuki 125 RV
water warrior is offline
post #8 of 13 Old 09-12-2006, 09:20 PM
805gregg's Avatar
It may not drag in the corners but if you go off road it will drag everywhere else, it sits down about 1 1/4" lower than suzuki and will hit on every rock.
805gregg is offline
post #9 of 13 Old 09-12-2006, 10:20 PM
GreatWhiteHunter's Avatar
Send a message via Yahoo to GreatWhiteHunter Send a message via Skype™ to GreatWhiteHunter
Does an older BMW count as a reference? If it does then I can say that my Strom is every bit as stable as my beemer. In fact I like the Motech stand better than the one on the ole 77.
I put my Strom up on the center stand whenever the ground is level enough.
2006 DL1000K6 (the fast, red one)
2010 KTM 530 XC-W
2009 KTM 300 XC
GreatWhiteHunter is offline
post #10 of 13 Old 09-19-2006, 05:24 AM
mokusbajusz's Avatar
Re: SW-Motech Centerstand Stability
If the bike is lowered via dog bone links, you will scrap the SW stand in left corners but only after the footpeg is fully bent up.
Balázs
DL650 K6 matt black
DL 650 info
EX-President VSCH
mokusbajusz is offline
