K and N air filter ? - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 22 Old 05-31-2004, 12:02 PM
roaddog8688
Anyone install a K & N on the V strom 650? I'm told it's part # SU-1002.
Replies appreciated.
post #2 of 22 Old 06-01-2004, 07:13 PM
azsidewalker
that's it
That is the correct K&N air filter for the DL1000. Use this link to look up K&N filters on all vehicals:
http://www.knfilterchargers.com/search/appsearch.aspx
post #3 of 22 Old 06-02-2004, 10:08 AM
roaddog8688
Air filter
Thanks Dave
That is the correct number for the 650 as well.
Did you install one and has it made a difference?
Jim
post #4 of 22 Old 06-02-2004, 08:01 PM
azsidewalker
No. I just got my K3 less that 2 weeks ago. I bought it from a dealer that was using it for his own bike and it only had 2100 miles on it. I will install one of the air filters once a few miles are added. I was looking for the K&N oil filters because I like the bolt on the end for tightening and loosening.
post #5 of 22 Old 06-04-2004, 09:25 PM
hawespipe
Be aware that many engine builders will void a warranty if you use a K&N. Cummins Diesel does not like them ate-all.
There is independent research that shows that they are no good. Yea, I know.....
But I've stuck with stock filters and just change them out more often and I've also opened up air boxes more if it can be done to a particual model. And, if you open up one end then ya gotta do the other end. Don't forget a good exhaust system that allows it to breath as well.
post #6 of 22 Old 06-04-2004, 11:10 PM
dbl_aitch
My experience with K&N was almost immediate engine damage, worn valve guides. They do pass lots of air. And lots of dirt. Buyer beware...
post #7 of 22 Old 06-16-2004, 07:03 PM
K&N
I dont have the exact details, but I looked into this a while back... there is a school of thought that says more air can decrease HP... I know that sounds crazy, but I saw some convincing dyno charts.... I cant find the article now, but I did find this quote on the mototune website "Air Filters (How Freer Breathing = Slower)"
http://mototuneusa.com
Who really knows?
skidmark is offline
post #8 of 22 Old 06-16-2004, 08:48 PM
Pauljo
Some dealers have dynos in their shop. My dealer has one. I think they get about $35 for a dyno run. I had my DL1000 dyno tested before and after adding my Remus pipes.
If you can find a dealer with a dyno, they may have already tested some machines for K&N filter replacements. Might be able to tell you if it always or just sometimes increases performance. There may be some differences between carb machines and FI machines too. I suspect that if you do both the K&N and a performance exhaust cannister, it would be time to consider an FI remap. And I'm pretty sure it would take all three to realize the best performance increase.
post #9 of 22 Old 07-20-2004, 11:34 AM
rocketman
kn filter
i installed a kn filter on my o2 dl 1000 and it works great! better gas mileage and better power ,ive got remus cans and remap ,and ign advand the kn was not out then so we tuned it to the stock filter. and then the kn came out and i switched to the kn and it ran so much better. :D
post #10 of 22 Old 08-28-2004, 01:23 PM
crash2much
K&N- wow
I've never heard anything bad about K&N filters- I always replace the stock with them when I buy something new. Thanks for the info to ponder. But it's funny to see so many who don't realize that more air in = more air out; change intake, change exhaust. What kind of fuel mileage improvement has the filter caused?
Air Filter Replacement, Is KN worth the bucks? grsa DL650 and DL650A - 2004 to 2011 32 03-13-2015 05:12 PM
K&N-what a difference a couple of letters make Master of Morris DL1000 from 2002-2012 9 05-02-2013 11:31 AM
Air Filter (DL-650) Modification Part 02, (Pictures) Black Lab V-Strom Modifications and Performance 14 09-01-2010 07:02 AM
$5.29 air filter for your V-Strom Gravehunter V-Strom Modifications and Performance 13 07-19-2009 11:41 AM
