Wilbers progressive fork springs installed, but... - Stromtrooper Forum : Suzuki V-Strom Motorcycle Forums
post #1 of 30 Old 08-24-2006, 10:26 PM Thread Starter
I rock at logic
LucasD's Avatar
... the instructions were in German. The pictures were clear though, so
I really couldn't screw things up that bad.
While I notice an improvement, it's not quite what I was
expecting, having read so many posts about what an
amazing difference the springs made for other people.
Anyway... the service manual states that the springs
should be installed with the tighter pitch at the bottom of
the fork, while Wilbers' instructions include a picture and an
"achtung" stating that the springs should be installed with the
tighter pitch at the top of the fork.
I installed them per the service manual, but I'm wondering
if it really makes a difference.
2006 DL650
"We've done four already, but now we're steady and then they went one, two, three, four..."
LucasD is offline
post #2 of 30 Old 08-25-2006, 12:06 AM
Jonnylotto's Avatar
Send a message via AIM to Jonnylotto
Always go with the manufacturer. There's a reason they want the tighter pitch up top. (Don't ask me, I use Sonic Springs straight rate).
JonnyLotto
DL-650K5
"Honor does not need to defend itself nor does Valor need to fly a pennant to say 'I am brave'.
This is Pride mistaking itself for Virtue."
Jonnylotto is offline
post #3 of 30 Old 08-25-2006, 12:22 AM Thread Starter
I rock at logic
LucasD's Avatar
I went with the service manual because the stock springs
were progressive and Suzuki installed them with the tighter
pitch at the bottom.
Maybe some physics major can explain why they'd work
better installed one way versus the other. :?
2006 DL650
LucasD is offline
post #4 of 30 Old 08-26-2006, 06:28 AM
MATTMAN's Avatar
Just put one one way and one the other. :lol: ...... :shock:
Anyway it shouldn't be too hard to swap them around.
650...Anything more than a handfull is wasted
MATTMAN is offline
post #5 of 30 Old 08-29-2006, 12:57 AM
Basses5
Tighter pitch should be at top so spring can get "progressively" stronger the more it's compressed. :roll:
post #6 of 30 Old 08-29-2006, 01:01 AM
Coil bind would happen on the bottom too.
post #7 of 30 Old 08-29-2006, 02:57 AM
Basses5
Yes I agree but the tighter coil displaces more oil resulting in a higher oil level and if the new ones have a more massive tighter coil resultant oil level would be higher.
post #8 of 30 Old 08-29-2006, 08:34 AM
Now that makes sense.
post #9 of 30 Old 08-29-2006, 03:33 PM Thread Starter
I rock at logic
LucasD's Avatar
I sent the question to Wilbers and got this reponse from Klaus Huenecke:
"No, it does not matter technically, the spring will work correctly either
way. The reason we say to install it with the tighter wound ends up is, that we want to reduce the unsprung weight on the wheel by as much as possible."
I guess I'll take them out and flip them over.
2006 DL650
LucasD is offline
post #10 of 30 Old 08-29-2006, 05:39 PM
Since the trapped air can add a little to the resistance to compression, bound coils down could be a little stiffer since they displace more oil and the air volume is therefore smaller. The unsprung weight thing was in my mental hard drive but apparently in a bad sector. :wink:
